586,094 active members*
3,952 visitors online*
    May 2009
    25
    Powermax 380 signals
    Hi everyone, after much searching I cannot seem to find the answer to this one. Does anyone know if a Powermax 380 has an "arc ok" type of signal available in it? I found the manuals, and the maintenance docs on it, but they do not have full schematics that I can tell.
    Just wondering if there is easy access to this signal, or if I will need a current transformer to provide this signal for a THC. Seems like it's a good idea to have this, I am just finishing development on my homebuilt PIC-based THC and could leave this feature out of the code, but from what I read, it's a good idea to have the THC able to shutdown the plasma if there are arc problems.....
    Thanks. -James
    Jan 2008
    2247
    Since the Powermax380 was designed and marketed by Hypertherm as a hand held plasma cutting system....it does not have any internal method of indicating that the arc is transferred to the plate (also known as "arc good", "arc transfer", "machine motion").
    The best way is to install a current sensor (Tom at C and CNC electronics sells them) on the work cable that clamps to the metal you plan to cut. Whenever the torch is cutting platre there is cutting current on this cable.....
    Jim Colt Hypertherm
  1. Ask for Fanuc OM-A M1/M2 connector signals
    By david_chen in forum Fanuc
    Last Post: 03-18-2011, 09:59 AM
  2. Replies: 2
    Last Post: 12-27-2007, 03:59 AM
  3. NC414 Controller Signals
    By krz2_2000 in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2007, 01:03 PM
  4. Multiple Signals on a Cable
    By cibressus in forum CNC Machine Related Electronics
    Last Post: 08-19-2006, 11:59 PM
  5. To convert Quadrature Encoder signals to Tachogenerator signals
    By Babar in forum CNC Machine Related Electronics
    Last Post: 02-21-2006, 07:05 AM
