586,052 active members*
4,357 visitors online*
Thread: DPRNT help
    Sep 2008
    5
    DPRNT help
    I am trying to print values to a file on a pc. I have connection via RS-232 cables and IP address.
    Here is basically what I wish to print out
    Cycle Start (timestamp)
    Tool Number (timestamp)
    etc.....
    End of Cycle (timestamp)
    Idle time (timestamp)
    and repeat......
    I have figured out how to get the lettering and tool number variable onto my computer. Now I am just having trouble timestamping each operation.
    do I use #3011 and #3012 (date and time)?
    or do I split these up into individual variables like #101= year, #102=month....etc.....
    Also, how can I set the macro program to be called up by Mcode or Gcode....for example: every time G20 is read, the macro to DPRNT [cycle start] and timestamp it gets called up....or every time M30 is read, the macro for DPRNT [end of cycle] gets called up
    Thanks in advance!
    Dec 2008
    717
    You may want to search a bit on this site. We've discussed this a bunch...
    Look here:
    http://www.cnczone.com/forums/haas_m...rinting-3.html
    If that doesn't answer your questions, then let us know.
    Tim
  1. DPRNT COMMAND
    By harinct in forum DNC Problems and Solutions
    Last Post: 12-21-2009, 11:38 AM
  2. Renishaw DPRNT
    By Ginger_Ninja54 in forum Haas Mills
    Last Post: 10-10-2009, 02:22 PM
  3. DPRNT on OSP7000M/OSP700M?
    By marcwdci in forum Okuma
    Last Post: 11-26-2007, 06:13 PM
  4. Do you use DPRNT?
    By gar in forum Haas Mills
    Last Post: 10-23-2007, 04:02 PM
  5. Macro DPRNT please help
    By MarkoH in forum G-Code Programing
    Last Post: 06-19-2006, 06:37 PM
