586,222 active members*
3,384 visitors online*
    Jun 2010
    Is this a harmonic drive?
    Aug 2008
    1166
    Looks like it - there seem to be teeth on the outside of the cup in one of the pics, but it's tough to tell for sure. I wouldn't buy it for that much money unless I could find specs on it to know what the allowable torque is.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Oct 2006
    13
    Yes it is, but according to part number it seems to me that it is size 11, 1:50 ratio component set and size 11 is very, very small - around 30mm in diameter. Ask seller if you want be sure. If you plan to use it for fourth axis, look for size 20 and bigger... Look here: Products | Component Sets | CSF Series Gearing Components :: Harmonic Drive LLC , there are similar ones.
    Jun 2010
    Thanks guys. I was hoping for a bigger unit. Harmonics LLC quoted me at over $2k each! Guess I'll keep looking on ebay
    May 2010
    307
    Keep in mind that you'll likely want a gear head rather than a component set. You'll have to add your own bearing if you go with the component set.
  1. Home Made 4th Axis with Harmonic Drive Unit!
    By widgitmaster in forum Benchtop Machines
    Last Post: 08-27-2017, 03:16 AM
  2. harmonic drive helps
    By confusion in forum Mechanical Calculations/Engineering Design
    Last Post: 09-10-2007, 10:29 PM
  3. harmonic drive, max RPM stepper or servo
    By Art Ransom in forum Mechanical Calculations/Engineering Design
    Last Post: 12-12-2006, 05:26 AM
  4. Harmonic Drive
    By juzwuz in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2005, 08:28 AM
  5. Harmonic drive - keeping position?
    By medved in forum Mechanical Calculations/Engineering Design
    Last Post: 12-01-2005, 01:49 AM
