586,106 active members*
2,987 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Lets build Computer Controlled Graphical Fountains
Page 16 of 17 614151617
Results 301 to 320 of 325
  1. #301
    Feb 2014
    9
    Very cool! Do you use atmospheric pressure or not?
    What is the first picture on video?Is it heart or "->"?
    Can you "print" text or pics?
  2. #302
    Jan 2013
    16
    The water header is at atmospheric pressure with about 5" of water in the header. I think the first image is just triangles.... cant remember.
    I can print text and images but as mentioned, the image is too small to see much detail. Will be much better once I get more valves functioning.
  3. #303
    Aug 2014
    Re: Lets build Computer Controlled Graphical Fountains
    Khalid, sounds like you have made upgrades to the software, can you post the latest VB?
    Awesome!
  4. #304
    Sep 2015
    thanks for all
  5. #305
    Apr 2006
    3498
    I lost VB program in hard drive crash
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  6. #306
    Apr 2006
    3498
    Going to make a step by step video and sharing all the electronics, programming.. What do you guys suggest?
  7. #307
    Apr 2006
    3498
    This is just a video to show how the Proteus, Virtual Serial Port Driver, and VB6 interact without using any hardware.
    1- VB6 Graphical Waterfall sent a "byte" to the Proteus.
    2- ArduinoUno recieve the 'byte' with a special protocol and send it to shift register 74HC595.
    3- Arduino then send the same byte back to the VB6 software. which verify it and send the next byte.
    All this happening virtually.
    https://www.youtube.com/watch?v=jb0NBVotndE
  8. #308
    Apr 2006
    3498
    some more updates...No more computer intervention..
    A simulation of the graphical waterfall that will get the designs from SD card and send to the solenoids. LCD 20x4 shows basic information. The designs can be repeated . The programming was done in a way to reject the files which having wrong data and store the files name in the EEPROM. Total 50 filenames can be stored in EEPROM. The time delay between the rows of drops can be adjusted using potentiometer.
    https://youtu.be/ImPIyfoaqVw
  9. #309
    Apr 2006
    3498
    The final PCB went to PCB manufacturer
  10. #310
    Feb 2010
    3447
    How much did it cost to make the pcb?
    Sent from my SM-N910V using Tapatalk
  11. #311
    Apr 2006
    3498
    I ordered these 10 PCBs for an amount of 10US dollar for 10 pieces double sided. 11US dollar was shipping fees. Total 21US dollar. its about 75mm x75mm.
  12. #312
    Apr 2006
    3498
    Finally recieved the PCB from Pcbway.com... I will say amazing quality fast shipping and low cost. Thumbs up..
    Attached Thumbnails Attached Thumbnails 14232425_10207524069328698_323311476864961042_n.jpg   14322522_10207524070008715_3932437772584288453_n.jpg
  13. #313
    If anyone is from Pune, should go and buy from abc chowk. There are lots of wholesale dealer where can buy at cheapest and best rate. Good Quality products.
  14. #314
    Dec 2016
    Hi Khalid..
    Can you help me for this problem?
  15. #315
    Mar 2017
    hello, Khalid, I've been following this thread and it's amazing! I'm actually an intern and I also doing this project. I've been struggling with the programming this past 4 weeks, so if it's okay, do you mind sharing the code for this water fountain? hopefully so, because it will help me to learn a lot. and what kind of Arduino or PLC are you using? is it any different if I'm using Beckhoff PLC? hope to hear from you soon! thankyou before.
    Best regards, Thomas
  16. #316
    Jul 2016
    660
    You can just buy a raspberry + senseHAT module, that will give you 192 channels fully programmable output on a single script, you can loop it, time it, sound activate it, to cut the story short, you can do whatever you like on the 192 channel output you can even play ping pong thru a joystick on the water fountains, tetris, minecraft hehe
  17. #317
    Jan 2016
    Una parte del codigo esta mal, busca en el compilador la parte del codigo que esta con error debe salir resaltada en azul luego borrarla y vuelve a compilar y el software va a funcionar .
  18. #318
    Apr 2006
    3498
  19. #319
    Apr 2006
    3498
    electronics enclosure:
    Attached Thumbnails Attached Thumbnails 38680507_10212932945507222_5523689905319837696_n.jpg
  20. #320
    Apr 2006
    3498
    And the 3D printed part.
    Attached Thumbnails Attached Thumbnails 38744599_10212936921926630_367830881949188096_n.jpg   38760914_10212936922846653_412973320397389824_n.jpg
  1. A computer controlled etch a sketch for fun
    By jfong in forum Hobby Discussion
    Last Post: 07-05-2014, 07:04 AM
  2. Lets Build CNC Time Fountain
    By Khalid in forum Mechanical Calculations/Engineering Design
    Last Post: 03-08-2014, 12:49 PM
  3. Lets build a cnc robotic arm!!
    By patriciooholegu in forum DIY CNC Router Table Machines
    Last Post: 02-25-2012, 12:37 AM
  4. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors / Drives
    Last Post: 02-07-2008, 07:38 PM
  5. Replies: 9
    Last Post: 06-17-2006, 06:23 PM
