586,075 active members*
3,919 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Programming W axis in V21
Results 1 to 12 of 12
    Apr 2008
    46
    I am using Bob Cad V21 to generate G-code for a Centroid M400 contolled machine. However I now have a machine with a W axis. For certain sections of the program I need the W & Z axis to work together. Currently I have to go back and enter in the values for W manually . I was hoping it maybe possible to setup another configuration that automatically put in W values. I could switch between this & my standard configuration when I only need to cut with the Z axis.
    Any ideas how to do this.
    Richard
    Mar 2005
    368
    Is the W a direct replacement for another axis, such that the outputted value is correct and you just need to change say all the Xs to Ws?
    If so:
    On the CAM side, go to Setup > Conversion.
    Enter an Original character and the Convert To character.
    All new posted code will be converted.
    (as I type this, I don't know if it converts scripted code....but that can be dealt with)
    Apr 2008
    46
    I will try that but I am not sure that will work as I would need to convert Various Z values to z & W values.
    For example Z1 would become Z1 W1. It looks like this would give me ZW1 & I am not sure this would work.
    I will try though & thanks for the help.
    Mar 2005
    368
    Nope...the conversion feature probably won't work.
    Is it just in canned cycles that you need to change?
    I can't find a Centroid G-code list online...do you know of one?
    With more info, I can give better answers.
    Apr 2008
    46
    I tried your suggestion moldmaker. Unfortunately it didn't work out to well. I end up with ZW1 which I don't think will work.
    I can see it would work for a direct switch from a Z to W axis but I am running both spindles together so I need both Z and W to have a value.
    I think there is a code to slave both axes but I beileve I have to unlock a parameter in the controller.
    Currently I post all my code with Z values then use the search & replace command to convert the required instances to Z & W. I have to repeat this for every Z value. I also can't use replace all at some points I am running just the spindle on the Z axis.
    It's not to bad as I don't have many difernt Z Values, typically 4 or 5 per program. However anything that saves me time & removes chance of human error has to be a good thing.
    Any other input welcome.
    Apr 2008
    46
    I may have a PDF of the manual here. If not I have it at the shop & could post it tomorrow.
    As for canned cycles I have not really used them to much with the excepton of drilling. It maybe something like that.
    I'll take a look for the G-codes
    Mar 2005
    368
    I see....
    Does the W relate to the Z moves for a subspindle?
    Or is it for a tailstock move?
    I'm trying to picture if a script can be written that would give you what you need.
    Apr 2008
    46
    This is alink to the Centroid M400 manual
    http://cncsnw.com/232MillManual.pdf
    Apr 2008
    46
    I am not sure what you mean. My technical knowledge is not really up to scratch.
    Basically I have to routers routing identical parts at the same time. So the Z axis router is cutting at one position along the x axis & the W ais router is cutting an identical part further along the x axis.
    Then at some points I have to switch tools, this is where I just run 1 spindle as I only have an automatic tool changer for the Z axis Router. So at this point my W axis raises up to a rapid position then I do all my routing with the Z axis spindle.
    Does this make sense?
    Apr 2008
    46
    If you look at page 222 in the manual you will see there is a parameter 64 which can pair the 2 axes together. However this can only be turned on & off manually when a program is not running, unless I pay to unlock programmable parameters, in which case I could change the value of this parameter whenever i want.
    So I want to explore all the options for scripting or posting code before I shell out for this feature, especially as it's not my machine & I am having a hard time convincing the owner of the merits of unlocking this feature.
    Perhaps I should proof read my files a little less carefully and have a few W axis crashes...!!! That may make up his mind even if it's a little morally suspect.
    Mar 2005
    368
    Nowww I see....
    I was speaking lathe and you're speaking router.
    So you need code that would send the secondary spindle to W axis home prior to each toolchange?
    Perhaps you can show me your g-code before and after edit. So I can see what you're changing. Be sure to include all instances where you need it changed.
    Apr 2008
    46
    I'll dig something upn the morning.
    Thank you very much for the support..
  1. New to 4 and 5 axis programming
    By jcnewbie in forum Uncategorised CAM Discussion
    Last Post: 10-07-2009, 04:52 PM
  2. 4 axis programming
    By slideleft in forum G-Code Programing
    Last Post: 12-30-2008, 08:08 PM
  3. 4-axis, 3+2, or 4+ axis programming system?
    By roboticist in forum Uncategorised CAM Discussion
    Last Post: 09-04-2006, 07:02 PM
  4. 4th axis programming
    By smoggy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2005, 05:16 PM
  5. 4 and 5 axis programming
    By Cammotion in forum G-Code Programing
    Last Post: 03-03-2005, 06:39 AM
