586,100 active members*
3,115 visitors online*
    Sep 2007
    19
    Question Mazak ST40N ATC Alarms
    Hello Everybody,
    Machine: Mazak ST40N ATC
    Control: Mazatrol CAM T-3
    Question1:
    After homing (first X then Z or first Z then X) the following alarm appears;
    102 STORED STROKE LIMIT -X
    What is the reason? Should I change a parameter related to soft limits?
    Question2:
    This machine has also a C Axis but it is not servo. There is a gear system that can rotate the chuck min 1°. It has no interpolation with other axes.
    Now the machine shows;
    257 C-AXIS OR SHIFT LS MALFUNCTION
    And the led on "C-AXIS I/O" key blinks. Can you advise?
    Question3:
    Do you have a list that explains all the parameters one by one?
    Thanks in advance.
    Best Regards,
    Mert
    Mar 2009
    109
    The first problem is definitely a soft limit problem. Change the parameter.
    Also, I'm in need of parameters for this machine. Would you be able to help me out??
    Mar 2005
    73
    I have the same 257 alarm. Any advice?
    "Fire is cool" -Beavis
    Mar 2016
    Re: Mazak ST40N ATC Alarms
    Hello
    do you find the list of explains all the parameters one by one
    and can you give me a picture of m and op parameters of your machine
    thx
  1. Mazak ST40N Gear selection
    By modulus in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2016, 02:25 PM
  2. Mazak Slant 30 ATC/MC Multiple Alarms
    By BetaBob in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-25-2013, 01:31 AM
  3. SOLVED...Mazak QT20 several alarms
    By SINUMERIKO in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-08-2010, 07:10 PM
  4. Mazak alarms strike again
    By trademarkmachin in forum DNC Problems and Solutions
    Last Post: 09-02-2007, 09:05 AM
  5. Mazak T1 Alarms
    By mbpp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2007, 05:27 AM
