Frame Sizes
Servo Motor:Servo motors are availible in a wide variety of frame sizes, from small to large motors capable of running huge machines. Many of the motors come in NEMA standard sized.
Stepper Motor:Stepper motors do not have as many size selections as servo motors in the large sizes. However stepper motors may still be found in a variety of NEMA frame sizes.
Setup Complexity
Servo Motor:Servo motors require tuning of the (PID) closed loop variable circuit to obtain correct motor function.
Stepper Motor:Stepper motors are almost plug-and-play. They require only the motor wires to be wired to the stepper motor driver.
Motor Life
Servo Motor:The brushes on servo motors must be replaced every 2000 hours of operation. Also encoders may need replacing.
Stepper Motor:The bearing on stepper motors are the only wearing parts. That gives stepper motors a slight edge on life.
