586,065 active members*
4,842 visitors online*
    Serial CNC Software?
    I'm a total CNC newbie, and I've just build a cheap Milford CNC machine (1/2 way down this page : http://www.milinst.com/robotics/robotics.htm)
    However, the included software can only plot HPGL files which is no good for my gcode PCB files. Is there any way I can either convert them, or plot gcode directly to this machine?
    Your best bet would be to buy a HobbyCNC or Xylotex parallel port driver board that will let you use TurboCNC or Mach3 to control the machine.
    Ah, so there is no software solution to do it with the current board?
    Not that I'm aware of for less than $1000
