here is what I have: Cimatron 3X drill seq. out puts a positive Z. and my post out puts a positive Z. I need a negative Z???
thanks.
IF (VAR_SET (CYCLE_4)) // <Spot Drill>
OUTPUT $ "CYCL DEF 203 UNIVERSAL DRILLING ~";
OUTPUT \J TAB_ "Q200=" CYC_CLEAR TAB_ ";SET-UP CLEARANCE ~";
OUTPUT \J TAB_ "Q201=" CYC_DEPTH TAB_ ";DEPTH ~";
OUTPUT \J TAB_ "Q206=" MCH_FEED TAB_ ";FEED RATE FOR PLUNGING ~";
OUTPUT \J TAB_ "Q202=" CYC_PECK TAB_ ";PLUNGING DEPTH ~";
OUTPUT \J TAB_ "Q210=" "0" TAB_ ";DWELL TIME AT TOP ~";
OUTPUT \J TAB_ "Q203=" Z_CURPOS TAB_ ";SURFACE COORDINATE ~";
OUTPUT \J TAB_ "Q204=" CYC_DZINIT TAB_ ";2ND SET-UP CLEARANCE ~";
OUTPUT \J TAB_ "Q212=" CYC_REDUC TAB_ ";DECREMENT ~";
OUTPUT \J TAB_ "Q213=" "3" TAB_ ";BREAKS ~";
OUTPUT \J TAB_ "Q205=" CYC_REDUC TAB_ ";MIN. PLUNGING DEPTH ~";
OUTPUT \J TAB_ "Q211=" CYC_DWELL TAB_ ";DWELL TIME AT DEPTH ~";
OUTPUT \J TAB_ "Q208=" "200" TAB_ ";RETRACTION FEED RATE ~";
OUTPUT \J TAB_ "Q256=" "0.05" TAB_ ";DIST. FOR CHIP BRKNG ";
END_IF;
