586,094 active members*
3,891 visitors online*
Results 1 to 9 of 9
    Feb 2011
    4
    Bridgeport Gross positioning error
    Gday
    I got a Interact 308.
    When i start the machine and start the Z reference the X is slowly moving also. Then i get the Gross positioning error.
    Is the Clamps for the X stuffed???
    What can i do???
    Luke
    Nov 2004
    3028
    If a axis drifts it means that the positioning system is compromised. Typically encoder or cable. Swap x and Y motors and see if the problem follows the motor.
    Also there were different versions of controls on the 308. The later ones had siemens drives.
    George
    Feb 2011
    4
    Hey
    Thanks. I have begun to swap motors.
    Before i start pulling them out i found i was able to turn the X motor by hand but the y wont move.
    Is the motor the only thing that keeps it still when not in use or are there clamps when stationary?
    Does this narrow it down at all.
    Im guessing that by swaping motors i can see if the wires are stuffed or the motor?
    Luke
    Nov 2004
    3028
    Z has a brake. Y does not and should move (and home 2nd). X should not drift but home when the Y is finished. Sounds as if you have multiple issues.
    George
    Nov 2004
    3028
    George
    Feb 2011
    4
    Well i swapped motors anyway... it seems to have fixed something... dont know why.
    I can no longer move x by hand...
    We will see how long it lasts with the motors swapped.
    May 2004
    402
    Motors swopped
    Which would imply that you had a bad connection somewhere that you have moved as the motors were exchanged. I'd do a 'wriggle & tap' test 'in the manner of a reasonable man' on your various leads, plugs etc
    Andrew Mawson
    East Sussex, UK
    1121
    May 2004
    402
    Reasonable Men
    Quote Originally Posted by gus View Post
    This phrase was written into the backplane testing specification for Ferranti Argus 500 process control computers back in the 70's, where we were called upon to tap on the multi-layer plus wire wrapped backplane with a screwdriver handle 'in the manner of a reasonable man'. It did on occassions show up intermittant faults. Ferranti in those days was a company run by gentlemen, and such style of phrasing was not uncommon! I was with them for the best part of thirty years in one role or another.
    Andrew Mawson
    East Sussex, UK
  1. Gross Positioning Error
    By Shanghyd in forum Bridgeport / Hardinge Mills
    Last Post: 01-21-2010, 02:33 PM
  2. "Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2
    By MeTri in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2009, 06:37 AM
  3. Bridgeport Interact 4-Gross Positioning Error
    By foolmaker in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2009, 10:13 PM
  4. HELP! Gross positioning error
    By crazeekev in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2008, 04:11 PM
  5. Bridgeport VMC308 - Gross Position Error
    By mcwmah in forum Community Club House
    Last Post: 11-09-2007, 10:34 PM
