Hi.
We recently bought a Mikron with tnc355 control. Everything worked fine until yesterday when i was starting up the machine.
First i saw some yellow lines flipping around on the monitor and then -- Black!
Nothing can be done with the control. CE --> power on does´nt work either.
When i came home i found the service manual and how to fault find the monitor ( remove the monitor cable and check for a yellow field on the screen ).
My question is. If the monitor is fine i guess it´s the CLP board causing this? Does anyone know what the common failure on this board is and how to repair it? I work with cnc machines all day long but only the mechanical bit, but have friends who are very good with the electrical. So if we know what to look for maybe we can fix this board.
/Johan.
