586,069 active members*
3,662 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Fusion X2 kit - possible to swap over X-axis?
    Dec 2010
    116
    Has anybody seen or swapped the stepper mount/motor to the opposite end of the X-axis on the CNC Fusion X2 mill kit? I'd like to do this as it would make for a neater drive-cable layout in my setup.
    Aug 2009
    986
    The X axis hardware isn't symmetrical, and so just turning it around won't work without a lot of fabrication. You would need a longer ballscrew, and a new thrust bearing holder/motor mount. And the table extension still needs to stay on the right hand end, because that's where the ballnut lives.
    In short, it would be a real pain, and negates the bolt-on advantage of CNCFusion's kit.
    The easiest way to do it would be to turn the table and the saddle around 180 degrees. Then everything on the X axis will bolt up in stock form. The Y axis should work OK, because it's a fairly symmetrical setup.
    (Don't quote me on this. I am going from memory. Take your own measurements and do your own math.)
    Your X axis gib screws will be on the back of the table, as will the locking bolt for the Y axis ballscrew. If that's worth it to you, then that's probably the way to go.
    Frederic
    Dec 2010
    116
    Thanks Frederic, it sounds too hard, plus it's not a major issue which side it's on anyway.
    Cheers,
    Steph
  1. X2 CNC Fusion #4 Kit Y-axis Mod
    By Steoh in forum Benchtop Machines
    Last Post: 01-08-2011, 09:29 PM
  2. Swap axis feature..possible with Fanuc 6MB..?
    By Leblondmakino in forum Fanuc
    Last Post: 12-26-2009, 04:35 AM
  3. Shoda NC516p/Fanuc 15-M axis swap?
    By steve31086 in forum Commercial CNC Wood Routers
    Last Post: 11-18-2008, 08:31 PM
  4. Spindle motor swap, or servo swap?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 10-09-2007, 06:54 AM
  5. X2 Z axis Spring and Fusion CNC Kit
    By Woodenspoke in forum Benchtop Machines
    Last Post: 02-06-2007, 01:01 AM
