586,121 active members*
3,099 visitors online*
Results 1 to 6 of 6
    Feb 2011
    help with speeds
    I am machining brass in a small haas that the max rpm is 4000. the carbide mill i want to use is .250 which it says to use a speed of 11000. Is it ok to run in my machine at the 4000 rpm or would it just be best to switch to some HSS cutters??
    Apr 2005
    713
    You could run that tool at 100 RPM*, it's just not going to work as well as 10,000 RPM.
    *Not recommended.
    Apr 2010
    59
    You can run carbide into brass at 4000 rpm. If I were you I would run HSS first, because I don't think you'll see any performance gain from carbide if your max rpm is 4000. Try both, see which one you like best.
    Feb 2011
    thanks for the info... i know the brass is soft so usinG HSS is ok just. I just had a carbide cutter so i thought i would ask... thanks for the ideas guys
    May 2009
    30
    I WILL DO IT 1200RPM F10.
    Feb 2007
    381
    Personally, I don't care if you only have a 2500 rpm spindle. I would pick the carbide mill in a heart beat. You can run that carbide mill all day long and at the end of the day, you wouldn't see any wear. The HSS mill on the other hand, while it sure won't be junk, it will have some wear which will degrade your surface finish somewhat. Brass is very abrasive.
    Good luck and have fun!
    Mike
  1. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
  2. speeds and feeds
    By stevieboy in forum MetalWork Discussion
    Last Post: 03-09-2008, 03:55 PM
  3. Need some help with speeds & feeds
    By ldkell_2000 in forum MetalWork Discussion
    Last Post: 03-01-2008, 05:35 PM
  4. feeds and speeds
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 08-31-2007, 01:52 AM
  5. Reasonable speeds for a cnc?
    By Oce in forum Linear and Rotary Motion
    Last Post: 02-12-2007, 09:30 PM
