Originally Posted by
doorknob
That said, here are some tips that may help you:
- it helps to use a center punch as close to the intended hole positions as you can get, in order to minimize wandering of the drill bit when you first start making the holes
- start by drilling pilot holes at the center-punched locations
- the best drill bit to use for a pilot hole is probably what is called a "spotting" drill that has a relatively shorter length than standard "jobber length" drill bits
- when I didn't have a spotting drill bit, I have used a "center drill" bit for making pilot holes (a center drill bit is designed for drilling a hole to hold the end of a workpiece in a tailstock-mounted lathe center - the drill has a very thick body so that it does not flex very much)
- you will want to use progressively larger drill bits to enlarge the pilot hole step by step until you reach the final desired size. To determine which drill bit sizes to use for each successive drilling step, first look for a drawing that labels the parts of a drill bit and find the part called the "web" of the drill - one recommended practice is to make sure that the length of the web matches (or is slightly smaller than) the diameter of the previously-drilled hole that you are drilling out to a greater diameter. I don't think that you can look up the web length of a particular drill bit in a table, rather it's something that you will probably have to measure on individual drill bits.
- if the aluminum block that you are drilling is somewhat thick, you may find that "peck drilling" (drilling for a short depth, then withdrawing the drill bit, then drilling another short depth, and so forth) will give you better results than simply trying to plunge all the way through the entire hole.
- as for choice of drill bit material, I would look for plain "HSS" (high speed steel) bits, and avoid bits coated with titanium nitride or cobalt bits
As far as surface finish goes, maybe you should reconsider anodizing if you want a hard surface. I'm no expert, but I do not know of any surface treatment that you can apply that can give you the hardness of an anodized finish. You may be able to do the anodizing by yourself instead of using a job shop to do it, but that's a whole different discussion.
Hope that helps...
