I have a bridgeport Milling machine outfitted with Prototrak M3 and what I'm finding is that milling simple contours etc is a chore due to the counterintuitive controls & lack of documentation, not to mention the inability to export dxf files into its 3.5 floppy (due to lack of postprocessor which at least to the best of my knowledge would cost far more than mach 3 & a postprocessor for it)
I have been struggling with the fact that I have to do all the programming at the machine itself and therefore dont want to spend 5 hours standing next to the machine plugging in all the parameters to mill a relatively simple part when I already have a 3-d model in my computer that I SHOULD be able to shunt through a post-processor in the office and just pull up on the computer driving the mill.
essentially what I'm interested in doing is to pull the prototrack m3 and replace it with a real computer (dos-based 3.5 floppy, what a joke) running Mach 3. My question to anyone here who has done this is the following, am I going to end up having to rip all the wiring etc out and invest in a new servo controller (driver?) as well? anyone who has done this before your help is MUCH appreciated. (also, is there a better solution?)
I also have a torchmate x-y plasma table that I am contemplating swapping from the torchmate controlling interface to mach 3 so as to make any cnc item I use share a common control interface (looking to build my own x-y table that will also do wood routing so instead of 3 different programs to learn, anyone in my shop only has to learn one program but just more ways to use it)
so, has anyone done this before? really looking to preserve as many components that exist on the mill & table to cut costs, it would otherwise be a simple "replacement kit" which would be extremely easy (but likely much more costly)
