Originally Posted by
adprinter
You won't find it in their sales papers, go to one of their stores and look. I bought two of the Drill Press cross-slide tables, and took them apart desiring to use the longer axis from both tables to combine them into one. (The Drill Press cross-slides feature a Vise, instead of a table).
However, I had to do some cutting, and then surface grinding of the cuts in order to even fit them together, as the dovetail widths differ from the top and bottom slides. This left the casting so thin, that it broke the first time I put it under any load.
Seems the Chinese engineers knew what they were doing, as they purposely designed them this way to prevent someone from doing just what you are attempting to do. I haven't taken my mill table apart, in order to take precise measurements of the dovetails. But I suspect that it too, is designed similarly. $261? It may be worth the price, but DON'T attempt to modify it. Simply bolt the second one onto the first one and use it as is. This would still give you the increased axis travel, with the additional capability of of an additional axis of movement.
