I have an old Northern Drill Press, which has a MT2 taper spindle. I have added an XY mill table, hoping to use the machine as a mill. However, the spindle of the Drill features a solid spline shaft, which drives a tube with a MT2 taper. Is it possible to replace this assembly with a tube type shaft, so that a drawbar can be used to secure the chuck, or collets? Has anyone else done this particular conversion? I am not in my shop to check the dimensions, but as I recall the spline shaft diameter is rather small. Like .750" or maybe even 1".
