586,115 active members*
3,380 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > Employment Opportunity > Small batch of Acrylic 80mm-diameter "rings" needed
Results 1 to 9 of 9
    Oct 2010
    11
    Hi everyone,
    I need a quote for the following:
    • 48 total: 80mm OD x 60mm ID x .25in thick in Frosted White
    • 24 total: 75mm OD x 55mm ID x .25in thick in Frosted White
    I am currently paying $1.25/piece, so I would like to pay the same or less if possible.
    This is all I need for the first order, thought I will need more in the future.
    See attached photo for example:
    Apr 2008
    204
    I will see what I can get you a quote for tomorrow.
    Apr 2008
    204
    I am just checking out the types of frosted and notice that there are more than just one for white. Do you have a reference number for the type of frosted white you used last time for this product. This way I can match it as closely as possible.
    Aug 2010
    128
    questions
    What tollerances are you looking for? Do you have a certain finish in mind? How do you want the corners treated?
    Oct 2010
    11
    As mentioned before I am currently paying $1.25 per piece. I received a quote from one person wanting over $4.75 each. That is obviously way too much and I would like to find someone who can produce these for closer to the $1.25 price I have been paying.
    Here are some more photos to show exactly what I need.
    The ring with paper on it is how I have been getting them. Once you peel the paper off they are clear. I then sand both sides to make the acrylic look frosted.
    I would like the new rings to be made out of frosted acrylic so I do not have to sand them by hand.
    Aug 2010
    107
    I found the frosted acrylic material and it was $150.00 for 24"x48" sheet. That's $2.08 a part just in material. I'm glad you know what you want, what I'd like to know is why you stopped having them made for $1.25 part.
    Oct 2010
    11
    Quote Originally Posted by azmachining View Post
    my current producer is swamped with work and he said it would be at least a month before he could make more for me.
    still, i'm open to getting more quotes. even if the price is above what i was paying before...
    Sep 2010
    166
    This seems like a simple laser job. Why cant you take a clear sheet and sand it before you have them cut? A palm sander and some fine grit paper and you could have a whole 4'x8' sheet "frosted" in no time.
    Alternatively, couldnt you toss them in a vibratory tumbler with some grit? 15mins would be enough time to frost them up.
    Jul 2007
    148
    I'm not interested in quoting but you could probably get the look you are after by bead blasting the parts using glass beads.
  1. Small diameter (.125") double compression router bits?
    By stevespo in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-02-2016, 02:07 PM
  2. WTB: 18" diameter .125~ wall stainless tubing, 18" long piece
    By m-134b in forum Want To Buy...Need help!
    Last Post: 11-01-2012, 06:20 AM
  3. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  4. Power needed to cut 1/16" ABS and 1/8" Acrylic?
    By SRT Mike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2007, 04:24 AM
  5. Replies: 1
    Last Post: 01-05-2007, 04:46 AM
