586,357 active members*
3,497 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1985 VMC-40 OS and Memory upgrade
    Aug 2005
    Have an oppurtunity to buy a 1985 VMC-40 w/38k and -1 software (OS = 87.1R), but I want to be 100% sure I can upgrade this machine (using Fadal parts) first.
    From what I have heard/read, I should be able to upgrade the OS by installing a 1400-4 or 1400-5 control board or is there many more boards/cabling that must be replaced in order to get an OS upgrade???
    I would also like to install the expanded memory (either 422k or 16Meg) My question is...Does the expanded memory board connect directly (piggyback) to the control board or does it plug into a different slot somewhere else in the back panel?
    One last question.. is it possible to put the Fadal legacy control panel (ie jog wheel, estop, etc) on this machine? Currently this machine just has a keyboard and monitor.
    thanks for any help you can give me.
    Feb 2005
    121
    me too me too
    ive just bought a 1984 vmc40 with a cnc88 system is this a ok system i havent fired it up yet im waiting on my 3ph inverter or should i just retrofit to a newer control ie centroid.???
    Jan 2004
    3154
    As per my other post to you.
    Upgrade to a Centroid or Fagor control would be perfect especially with the good mechanics you got sitting there.
    www.integratedmechanical.ca
    Aug 2003
    812
    To get 4-16 megs you need a current -5 control. This will involve replacement of just about every board in the control panel. The upgrade is about 5k, and can be done in a couple of hours.
    900
    Nervis1--
    You are right on the money. Any Legacy control (88hs) can be upgraded to the latest -5 system. The software version will be SYS 102.1. The upgrade kit contains all the boards required and a good tech should be able to change it all out in a few hours and then do any calibration that maybe needed like cal the R/tap.
    Neal
