586,089 active members*
3,709 visitors online*
Results 1 to 13 of 13
    May 2009
    1332
    Low RPM Spindle
    Forgot to ask the question here...
    What spindle do you use to cut Aluminum on your CNC?
    (preferably 110VAC or DC)
    Nicolas
    Aug 2008
    1166
    I use a PC890 router run at its lowest speed (~10k rpm). It's not amazing but works okay. I'm planning on using a mini-mill (X2 size) milling head with a dc motor in the (hopefully) near future. I plan to also use this as a drilling head. In theory you could use a higher speed spindle (maybe one of the Chinese spindles) to cut metal, but you'd need to move it fast to take full advantage of it and your machine would need to be rigid.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    May 2009
    1332
    I thought that even 10K RPM is high to cut aluminum. What I read is that 2K-3K is the ideal RPM to work in Aluminum.
    I have a VS Bosch Colt with an RPM range of 16K-30K. I wouldn’t even try to do anything in Aluminum at 16K RPM.
    Nicolas
    Aug 2008
    1166
    No, look at the spec's on the some real milling machines. Some go as high as 40k rpm. 10k rpm is typical. That's not to say it will work in your application. Those machines are much stiffer and can likely move faster while cutting than yours can if you have a typical router. If you can move faster you can get the chip load up into a more reasonable range so the cutting tool works properly.
    If you haven't tried your spindle, how do you know it won't work? I'm not saying it will, but trying it won't kill it. I've accidentally cut steel with mine (went through the side of a bolt in some aluminum) and it was fine. Take very light cuts, like 0.01" depth of cut with a 1 flute or 2 flute 1/4" tool maybe starting around 15ipm. I run 10k rpm with a 2 flute end mill which would be equivalent to running 20k rpm with a 1 flute. This will be a super small chip load for your cutter which isn't that great, but it works for the typical routers people are building here.
    Aug 2008
    142
    10k seems a bit slow to me. I haven't finished my machine yet to determine its capabilities. However, I cut .250 aluminum plate at work with a 5hp spindle running at 32000 rpm's with a feed rate of 70ipm. The average starting rpm is 18000 using a 1/4 single flute bit with a feed rate of 40ipm. I can cut 8 4'x'8x1/4" sheets full of 6" letters before I need to change the bit.
    Nov 2008
    412
    Use Super-PID to control your router speed. I cut aluminum @5000 rpm with my Milwaukee router controlled by Super-PID.
    www.SuperPID.com - Super-PID Closed-loop Router Speed Controller
    I have no financial gain out of this. Just an very happy customer.
    Forget about global warming...Visualize using your turn signal!
    May 2009
    1332
    Now that is good news for me, never thought about it but certainly I will give it a try
    Regarding the Supper-PID I’m aware of it and I may consider it in the near future
    Thank you all for the info
    Nicolas
    Apr 2009
    5516
    Quote Originally Posted by jsheerin View Post
    It wouldn't be hard to test. I believe for the Amana spiral O flute they recommend 120ipm at 18000rpm for 1/4" at 1/4" depth. I never attempted this. But what I did do was make 6 pockets about 3/8" wide and about 3 inches long. I set my feedrate at 100ipm but changed the depth on all 6 slots by .015", cutting each with one pass. I thought I would gall up the bit and break it. To my surprise it cut through all of them. I did get some edge burring at .090" pass, and I still have some backlash issues (new couplers sent with the wrong bore!) but .075" gave me a clean edge. just an anecdotal example to demonstrate how you could test cuts.
    May 2009
    1332
    I dont even cut wood at 100ipm LOL but I’m glad to hear that
    It looks like that my Colt will do the job
    Nicolas
    Apr 2009
    5516
    Quote Originally Posted by kolias View Post
    Heck, I used a Sears Craftsman trim router on my first machine! Granted, these aren't ideal conditions for cutting, but for occasional stuff, it's good to know it can be done.
    Nov 2008
    412
    You can cut almost anything with high rpm's provided sufficient federate. My preference is to slowdown the rpm so I can use high speed cutting tools vs the lot more expensive carbide tools. That why I was suggesting the S-PID in early post, it provides all the torque while cutting @ low rpm. It can control anything as long as it have brushes and powered by AC current. Hope this helps.
    May 2009
    1332
    I like the super-PID but I find it kind of expensive for now.
    Nicolas
    Apr 2010
    363
    Here I am cutting Mic-6 aluminum at 60IPM at 20-25k with my Porter Cable router. My stiffness is probably typical of most DIY machines here. This is using a 2 flute carbide 1/4 bit taking passes of .03.
    [nomedia="http://www.youtube.com/watch?v=jz1S7diyO_c&feature=email&email=comment_received"]YouTube - Crane's CNC Milling Aluminum[/nomedia]
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. spindle motor and spindle control dont work
    By customcncparts in forum Milltronics
    Last Post: 10-01-2009, 08:08 PM
  5. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
