586,036 active members*
3,532 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF2 tool carriage stalled midway
Results 1 to 8 of 8
    Mar 2011
    Hi I have a 1992 Haas VF2 and today midway thru a tool change the carriage stopped midway its now locked midway to the home position could it be a limit switch/ home switch ???
    Thanks in advance
    4826
    I've never had to mess with my toolchanger yet, but isn't there a crank arm that drives the carousel back and forth? I don't think the limit switch would cause the problem, because those would be activated at the end of stroke.
    Perhaps there is a fuse blown on the motor driving the crank arm?
    How do the wheels and guides look on the slideway for the carousel?
    Can you pull it into position manually?
    Could there be a broken key or pin in the crank arm actuator hub?
    First you get good, then you get fast. Then grouchiness sets in.
    Mar 2011
    Thanks I got the call and have yet to inspect it the operator stated he has fault code 125 I will be sure to look at all the items you suggested Thanks
    Quote Originally Posted by HuFlungDung View Post
    Mar 2011
    Thanks I got the call and have yet to inspect it the operator stated he has fault code 125 I will be sure to look at all the items you suggested Thanks for the quick reply
    Feb 2010
    1184
    The switches can most definitely be a cause for the alarm. Most common problem is that they get sticky and do not release quick enough. If they move freely, check the diagnostics page while manually pushing one each of the switches to make sure they toggle.
    Feb 2010
    I dont know how old you machine is but there is a roller bearing in there that rides in a slot on the aluminum casting. The bering in mine went bad and galled the aluminum and jammed itself.. Tool changer had to taken apart to replace the bearing. Cleaned the goues and blended the casting and was back up and running in about an hour after I got the bearing from the HFO.
    Sep 2006
    251
    Check your tool unclamp limit switch as well as the toolchanger limit switches. I had this many times.
    Just a good ol' boy, never meanin' no harm.
    Joe
    May 2006
    39
    I had a similar problem and it was the switches sticking. The tech sprayed them with a electronic contact cleaner to free them up.
  1. PBC Linear Retrofits Custom Simplicity Solution on Stalled Wood Sander
    By Pacific Bearing in forum News Announcements
    Last Post: 05-05-2010, 10:54 PM
  2. Carriage Wheel
    By bling59 in forum MetalWork Discussion
    Last Post: 06-16-2009, 04:57 PM
  3. Carriage Jam
    By jroma1 in forum Mini Lathe
    Last Post: 07-01-2008, 04:05 AM
  4. Questions on Z Carriage
    By Goran321 in forum Joes CNC Model 2006
    Last Post: 12-20-2007, 03:21 AM
  5. Stepper motor stalled
    By roni21702 in forum Stepper Motors / Drives
    Last Post: 06-10-2007, 01:25 AM
