586,119 active members*
3,626 visitors online*
Thread: Sodick A320D
Results 1 to 12 of 12
    Oct 2009
    27
    Sodick A320D
    I am running a SODICK A320D with a FINE SODICK EX21 power supply
    I hit the red all stop button last night as I do when nothing is running in the machine. When I came in I prepared to do a wire alignment when I was getting an error (164 I think) and something about a heat switch. and my axis are not responding to my button pushing. The numbers on the screen change but no table movement. Any help would be appreciated.
    Sep 2008
    51
    Not sure what's causing alarm, but the same thing happened to me before (heat switch).It seams that when you kill the machine with e-stop, then restart the next day, reset the e-stop button before main power switch is turned on. This works for my AP500 w/Mark25 control.
    1) reset e-stop
    2) main power on
    3)power up control
    Hope this helps, Good Luck!
    Oct 2009
    27
    Called up tech support from the Sodick web page. Few minutes on hold they answered. Much like you said. A complete shut down and reboot of the software. Just a few minutes later I was underway again.
    Mar 2009
    19
    Hello
    DO you still have Sodick Wire with Mark25 controle? I have a A520D, I am missing cutting technology table, I realy appreciate If I can get Pages for .008 and .010 wire cutting technology. Thanks [email protected]
    Oct 2009
    27
    Cutting Technology
    Surjit
    I am not really sure what it is your are asking, but if it is the software to run your control I don't have it for a mark 25. Sorry I couldn't be of much more help.
    Mar 2009
    19
    I need cutting condition for my A530D Mark 25
    Hi
    I lost my cutting condition book for my Sodick A530D mark 25 Wire EDM. I appreciate if you can make copy of .008 and .010 wire for steel. with regards
    [email protected]
    May 2011
    I am also running a SODICK A320D with a FINE SODICK EX21 power supply and am having the same problem.
    Any help with this would be greatly appreciated.
    Stan
    Dec 2011
    Same but not
    We are having the same issue, but, after powering down, re-booting, and starting the machine up again, it will run for a while, but then the same error, E164, will come up again.
    The machine faults out with E164 at no predictable time. It is intermittent.
    I expected to see the OL led on one of the servopacks to be on, but it is not.
    Loose wire maybe? If so, which one?
    It seems to fault just as the table should start moving, not in the middle of a move.
    The table seems to move easily in all directions without any bumping of hinderance.
    Please help!
    Thank you.
    Ric
    Grand Rapids, MI, USA
    Dec 2006
    131
    Ric,
    i would check to see if you have a broken wire. Also have you tried to swap motors to see if the problem stays with the axis. I saw in your pm that you did swap the servos and it stayed with x. If the servo faults out just about every LED on the servo will light up and stay on till you restart the machine.
    Dec 2011
    Thanks for reply!!!
    And Happy New Year.
    I will be looking for a loose wire, but unfortunately, I'm searching blind.
    I do not have any wiring diagrams for this machine.
    What sort of wire are you suggesting I look at?
    A feedback wire from an encoder maybe?
    Do you have any schematics scanned that are e-mailable?
    Thank you again for the reply.
    Ric del
    Dec 2006
    131
    I dont have any schematics to send but i usually check at the connection at the motor and trace it back best i can. I would try swapping motors from X to Y if the wires look clean. You may have an encoder that is going out so it is worth swapping them around since you will have the covers off already.
    Dec 2011
    Problem found?
    We think the issue has been resolved. Time will tell.
    What we did: On the plug sets that are mounted on a plate above the U and V axis motors, the receptacles in the female sides were straightened and squeezed down a little, so the pins on the male side would be gripped more.
    After disconnnecting the plugs, many of the receptacles were found to be a bit bent and their openings kind of large, leading us to think the connections were high resistance and intermittent.
    Like I said, so far so good.
    Does anyone know the manufacturer of the plug sets? Amphenol?
    Thanks.
  1. Needs help !!! Sodick A320D with AWT - Control EX21
    By mescotc in forum EDM Discussion General Topics
    Last Post: 08-22-2023, 06:44 PM
  2. Sodick A280L / A320D Keyboard Cover
    By Russ@EPP in forum EDM Discussion General Topics
    Last Post: 02-21-2010, 08:15 AM
  3. Sodick A320D help with flushing
    By XYZ machine in forum EDM Discussion General Topics
    Last Post: 02-19-2009, 03:53 AM
  4. wiring schematics for Sodick A320D
    Last Post: 01-10-2009, 06:23 AM
  5. UG NX4 PostProcessor for Sodick EX21 A320D
    By Chris 1st in forum UG NX
    Last Post: 01-06-2009, 01:22 PM
