I've got a piece of 6061 that I want turned into a sub plate. It's 1" x 8" x 27". It needs 216 holes, 1/4"x20tpi, spaced 1" apart. The holes need to go all the way through. I don't have a drawing yet but if you need one, let me know.
Thanks, Lee
Thanks, Lee
Hi Lee,
I take it that the holes start .5 inches in from the edges? Square pattern or other? Tollerances?
ABC-
Yes, the holes start .5" from the edges. The holes are in a square pattern. This will look like a sub plate but be used as the base plate for a model car/motorcycle frame jig. I'll make my own brackets for keeping everything lined up. The holes need to be precisely spaced, but if they start .532" from the edge on one side, it really won't matter. I can send a photo of a smaller one that I have. It was made for me several years ago as a sub plate for my Sherline mill. It works great for that, but at 9"x5", not so great for 1/8 scale car chassis or 1/6 motorcycle frames.
Ok Lee,
It sounds like standard .005 tollerances would be ok. I know you need the holes full depth. You need them threaded full depth?
If they're threaded most of the way, that would be fine. The main reason I want them all the way through is to be able to clean them.
Lee,
Quote in Private Message.
ABC
