586,121 active members*
3,580 visitors online*
Results 1 to 7 of 7
    Jun 2007
    11
    1 Sub Plate 216 holes
    I've got a piece of 6061 that I want turned into a sub plate. It's 1" x 8" x 27". It needs 216 holes, 1/4"x20tpi, spaced 1" apart. The holes need to go all the way through. I don't have a drawing yet but if you need one, let me know.
    Thanks, Lee
    Aug 2010
    128
    information request
    Hi Lee,
    I take it that the holes start .5 inches in from the edges? Square pattern or other? Tollerances?
    Jun 2007
    11
    Quote Originally Posted by abcmojave View Post
    Hi Lee,
    ABC-
    Yes, the holes start .5" from the edges. The holes are in a square pattern. This will look like a sub plate but be used as the base plate for a model car/motorcycle frame jig. I'll make my own brackets for keeping everything lined up. The holes need to be precisely spaced, but if they start .532" from the edge on one side, it really won't matter. I can send a photo of a smaller one that I have. It was made for me several years ago as a sub plate for my Sherline mill. It works great for that, but at 9"x5", not so great for 1/8 scale car chassis or 1/6 motorcycle frames.
    Aug 2010
    128
    information
    Ok Lee,
    It sounds like standard .005 tollerances would be ok. I know you need the holes full depth. You need them threaded full depth?
    Jun 2007
    11
    If they're threaded most of the way, that would be fine. The main reason I want them all the way through is to be able to clean them.
    Aug 2010
    128
    Ready to quote
    Lee,
    Quote in Private Message.
    ABC
    Jun 2007
    11
    Got it. Sold! thanks.
  1. Plate Beveling round holes? Plasma or Oxy/fuel
    By WSS in forum Waterjet General Topics
    Last Post: 01-07-2011, 07:55 AM
  2. How to cut say 3" holes in 1/2 aluminum plate???
    By wrechin2 in forum MetalWork Discussion
    Last Post: 01-25-2009, 05:09 PM
  3. Any tips for designing a fixture plate / tooling plate?
    By thackman in forum Benchtop Machines
    Last Post: 12-19-2008, 06:26 PM
  4. 1" holes in 1/4" 304 SS plate.
    By Loading in forum MetalWork Discussion
    Last Post: 10-26-2007, 01:33 AM
  5. Cutting Large Diameter Holes in Aluminum Plate
    By barkster in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2004, 11:44 AM
