586,069 active members*
3,538 visitors online*
Results 1 to 6 of 6
    Feb 2010
    SMARTCAM FONTS
    Does anyone know where to find straight line fonts. for smartcam 11.5
    All of the ones i have found all use some sort of radius!
    Gary
    2932
    I don't know of any created using line segments instead of arcs. Will your machine not interpolate an arc? You could change your .smf file (Q90) to output line segments instead of arcs...
    Feb 2010
    Quote Originally Posted by dcoupar View Post
    not sure what i have to replace (Q90) with .I do no how to change everthing but not sure what it is i am replacing?
    2932
    If you run Machine Define, and open your .SMF file, scroll down to Question 90, "Use arc command". Set that to 0, "No, interpolate arcs using line commands". Any time SmartCAM encounters an arc when generating code, it will output line segments instead. Question 91 sets the maximum deviation from a true arc. Small values here will create more line segments.
    Jan 2007
    1389
    or you can just explode the font into poly lines, no need to mess with code generators
    Feb 2010
    Thanks works great!
    Gary
  1. Anyone still using SmartCAM
    By ltmquik in forum Uncategorised CAM Discussion
    Last Post: 03-10-2013, 05:30 PM
  2. SmartCam 11.5
    By banshee671 in forum Uncategorised CAM Discussion
    Last Post: 02-15-2010, 06:52 PM
  3. SmartCAM V11 help
    By rai in forum Uncategorised CAM Discussion
    Last Post: 04-16-2009, 04:26 AM
  4. SmartCAM vs ?
    By riverracer in forum Uncategorised CAM Discussion
    Last Post: 07-22-2008, 05:35 PM
  5. SmartCAM Help
    By Linear360 in forum Uncategorised CAM Discussion
    Last Post: 05-20-2008, 03:19 PM
