tried to change 76 low air pressure got a servos on alarm and won't allow me to change.
So is your air pressure low then...?
Just hit emergency stop. You need to turn the servos off to change parameters.
Mike
Setting 7 has to be OFF and E-Stop pushed.
Beware...
Changing parameter 76 to a larger number won't fix the low air.
It will just keep the control from telling you that you have low air.
If the guage says pressure is below 85 PSI, adjust it or get a better supply.
If the guage is correct and get low air, the sensor is the cause.
