586,440 active members*
4,129 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Manual turning of stepper motors
    Apr 2003
    14
    Hi Group,
    Can damage be done to the stepper drivers if you manually turn the stepper motor shafts manually? Should I disconnect the motor wires before turning the motor by hand?
    Thanks in advance,
    pat
    Aug 2004
    2849
    Well darn...if the drivers are powered up and you can overcome the holding torque...then it's just like missing steps...shouldn't hurt anything...if they are powered down nothing should happen at all.....so, why do you want to turn the motor by hand?
