586,114 active members*
3,144 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Controller replacement recommendations for a Anilam 1400
Results 1 to 10 of 10
    May 2006
    11
    I am a newbie to cnc mills, but I have just acquired a fryer MC-32 with a old anilam 1400m controller. I can't seem to get the machine servos to engage as the machine can't seem to find the machine home. I am considering replacing the old controller with something more current? I do all the programming in CAD CAM and virtually no programming is done at the machine. Any thoughts on what controller I should use? The machine does have a 16 tool changer, coolant, reversing spindle etc to make things a little more funner. How long does it take to replace the control and how difficult is it? In time I would like to add a 4th or 5th axis as well.
    May 2011
    iam in the exact same situation my plc shows a cpu error which is halting the machine when i disconnect the plc iam able to enable servos and moves the axis servos.... but not the spindle which goes through the plc (slc-500) ive been looking day and night on what my options are....my machine is a tree 3016 with anilam 1400 have you resolved anything with your machine it sounds like the plc too.... before i figured out that if you change the baud rate on the controller setting to not talk to the plc it will aloow you to home the machine
    May 2006
    11
    I think your right, but I haven't had time recently to play with it. I will let you know as soon as I give it a try. I contacted motiontek, the guys were helpful. The controller they proposed for my machine ranged between 4 and 8 k. The downfall, is that I may have to replace the spindle and I would loose the ATC. With that being said, I will likely have to stick with anilam. Keep checking ebay, I saw a anilam 1400 system a couple of weeks ago for about $1000.
    Either way I will let you know as soon as I find some tinkering time.
    Jul 2007
    13
    Look at Centroid. They are a great control.
    24221
    Check out Dynomotion Kflop/kanalog, use it with Mach as a front end if need be, allows you to use the old analogue drives if you have them.
    Al.
    Albert E.
    May 2006
    11
    Do you know if either centroid or Dynomotion will be able to work with ATC. Keeping the existing drives is huge, and thanks for the advice.
    24221
    The ATC on just about any machine is dependant on the amount of I/O and the logic required, the logic is often carried out with an outboard PLC or the controller itself can provide it in the case of Dynomotion, email Tom at (Dynomotion) he willingly answers any questions.
    Al.
    Albert E.
    May 2011
    I need the plc program to upload to the slc -500 for anilam 1400 I have all the schematics. If I have to I will learn to write some ladder programs Can anyone point me in the right direction?
    24221
    As well as the RS-Logix s/w you need a AB interface unit/cable.
    I have an older version, it requires a floppy disk key to work, I am not sure if you can pick a copy up on ebay?
    Al.
    Albert E.
    May 2011
    Sorry. I meant to say I need the ladder program to send to the plc. I've already connected to the unit which gave a error of "no program". 0001f. I have the softwRe and cable to communicate to the plc. I need tge code. The EEPROM socket didn not have the chip. Iam curious if I can find some code to loud to it and swap some wires around.
  1. Need help - Anilam 1400 controller freezing on me
    By pchangover in forum Controller & Computer Solutions
    Last Post: 01-09-2013, 12:02 AM
  2. Anilam 1400 on Eagle 400
    By ts4tomh in forum Servo Motors / Drives
    Last Post: 05-22-2008, 06:01 AM
  3. 1100 and 1400 anilam cpu need new where to get
    By jetski in forum Milltronics
    Last Post: 11-27-2007, 06:22 PM
  4. Anilam 1400 software
    By quadbob in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2007, 08:34 PM
  5. PC to Anilam 1400 Setup
    By webson in forum Open Source CNC Machine Designs
    Last Post: 08-31-2006, 12:54 AM
