586,108 active members*
3,093 visitors online*
    Feb 2010
    Mach3 Write wizard bug?
    Hi all,
    I found something strange happening with the text wizard of Mach3:
    If you type "OTO" all capital and choose "Times New Roman" font
    the spacing between the first "O" and the "T" does not exist, but the spacing between the "T" and the second "O" is fine, and therefore a part of the first "O" gets over-writen by the "T"...
    Any solution around that?
    Ta,
    RNR
    Set the separation to 100
    Feb 2010
    Hi Gerry,
    Thank you for the reply.
    Yes, I could set it to 100, the T wont overlap the O anymore. But the spacing still shorter. It doesn't looks right.
    Is it a bug?
    Laurent
    OK, I see what you mean, that it's not centered between the O's.
    Whether it's a bug or not, would probably depend on who you ask. I don't think it takes into account which letters are adjacent to each other to vary the spacing,but just uses a generic spacing between all the letters.
    Regardless, you're stuck with it the way it is. The wizards included with Mach3 were all donated by users. The Write wizard was added many years ago. It's by far the most complex wizard included with mach3, with thousands of lines of code.
  1. Mach 3 write wizard
    By Jig Maker in forum Engraving Machines
    Last Post: 03-02-2011, 07:14 PM
  2. Write Wizard Help!
    By ibuildstuff4u in forum Mach Wizards, Macros, & Addons
    Last Post: 08-12-2009, 06:25 AM
  3. Write wizard...To many numbers
    By Scott_M in forum Mach Wizards, Macros, & Addons
    Last Post: 02-09-2007, 07:14 PM
  4. Mach 3 Write Wizard
    By rweatherly in forum Mach Wizards, Macros, & Addons
    Last Post: 12-18-2005, 11:25 PM
  5. Write Wizard Problem
    Last Post: 11-13-2005, 02:17 PM
