Personally unless the servo is brushless, which I doubt for that price, I'd stick with the 3 phase.
I have to say that I never cut aluminium with 4-flute tools. Not only are they terrible at plunging (many are not designed to) but the lack of flute clearance causes chip welding all the time for me. You could try ramping or helical plunging, but honestly I would stick with 2 flute tools regardless for aluminium. It's just safer even if theoretically you can't feed quite as fast. Especially because I don't want to run liquid coolant, I would always lean towards the more reliable but slower method and give up a little on the material removal rate. At the 500mm/min, 5DOC, 5000RPM that I ran on a test there's no way I would leave it unattended. If it jams the tool, a broken tool is the best I can expect. I leave my machine running for several hours at a time and I would go for peace of mind every time!
