How do i set up soft limits in mach3 and can i set a home without switches? if so how do i do both of these?
You can home without home switches, just click Ref All button, and it will set your home position wherever the machine is at that time.
Before I had home switches, I would jog my machine against it's hard stops, and Ref All there, so I had a repeatable home position.
Softlimits positions are set in Config > Homing/Limits, and toggled on and off with the Softlimits button on the run screen.
I try to send all 3 axis home before I close the program, but in the event I need to home from scratch I do the following....
Manually move each axis to it's hard stop
Start Mach3 and the controller
Set the jog mode to step and .1000 for stepping distance
Now I jog each axis twice and this will set it off the hard stops by .2
Then close and restart Mach3 and Ref All
so how do i input the data into the soft limits? Do i just input where i dont want it to go past or do i jog it over and set it?
Just type in the numbers
