586,094 active members*
3,949 visitors online*
    Sep 2007
    34
    My air over oil power drawbar
    There seems to be a big interest in power drawbars for the TTS system. This is a pic of my unit that I have been running for a few weeks. It runs on 75 to 80 PSI and has a drawbar pull of about 4000 lbs.
    I designed this system for affordability and relatively low air use. I think most people rather not use over 80 lbs air pressure. It is going to be a less expensive alternative to Tormachs triple cylinder.
    Etced
    Sep 2008
    325
    Etced,
    That is truly an "air over hydraulic" system in the literal sense!!!!!
    Nice job!
    Apr 2007
    2580
    Nice work man....
    Looks good too!! peace
    Pete
    Sep 2007
    34
    Thanks guys, I plan on offering these up for sale if there is enough interest, just need to put it thru a few thousand more cycles. The unit will be complete and ready to run with Hand valve and tubing for $700.00. All you need to provide is a air regulator from your compressor.
    Etced
  1. DIY Power Drawbar
    By bgolash in forum Benchtop Machines
    Last Post: 08-14-2009, 10:40 PM
  2. Power Drawbar Anyone?
    By gleas in forum Novakon
    Last Post: 07-20-2009, 01:34 AM
  3. Power drawbar
    By Bigbloke in forum Bridgeport / Hardinge Mills
    Last Post: 03-14-2009, 01:36 PM
  4. X2 power drawbar
    By X2cnc in forum Benchtop Machines
    Last Post: 09-20-2008, 01:39 AM
  5. power drawbar
    By fourperf in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2006, 03:28 AM
