Hi Guys,
Got a bit of an iddue. I have a Fadal 3016FX with Fanuc 0i control. I posted my problem on the Fadal section, but was advised to also post here, so here we go;
Had a noisy belt, so just changed that.
Try to run M84 to synch everything up and it errors:
1174 M84 LOGR ARBITRARY DATA ERROR
If I try to orient the spindle it errors:
9081 SPN 1 :S-SPINDLE ERROR (AL-081)
I'm gonna have a search for info now, but hoped that maybe someone has some words of widsom.
Possibly the hall effect sensor?
Just checked the hall effect sensor.
I measure 20V at the red wire/earth.
The green wire is 20V, and 0V when the magnet passes the sensor.
Since the above finding I have found a little damage on the end of the hall effect sensor. looks like something got trapped between the spindle pulley and sensor at some point. But it still reads the 20V. However, measuring another sensor shows 23.1V. I don't know if they should read the same or not.
Can someone assist?
Regards
Matt.
