586,075 active members*
4,087 visitors online*
Results 1 to 6 of 6
    Jan 2011
    10
    Foam in the laser tube and cooler
    Any idea why foaming would occur in the laser tube and in the cooler...i used a mixture of 50|50 (de-ionized water and propylene glycol).
    Oct 2010
    Not sure, I have a CW-5000 chiller and I run 50/50 automotive antifreeze/distilled water without any problems. Maybe flush the system out good with fresh water and refill it with a new mix, maybe some detergent from manufacturing was still in the tank??? That's my only guess.
    Feb 2005
    469
    If you let it run for awhile does it clear up or stay foamy? I just changed the water in mine yesterday and I also use distilled water and propylene glycol anti-freeze. When it first started with the fresh water it did produce some bubbles, but they cleared up in about a minute.
    Did you use pure propylene glycol mixed with water? I think the PG antifreeze has an anti-foaming agent added.
    Jan 2011
    10
    Smile
    the longer you let the cooler run the foaming issue gets even worse....i decided to drain the system and refill with de-ionized water...i think im gona leave it with plain water for now ....too anxious to get the darn thing going.
    ....I actually took some of that mixture filled half a container an shacked it for a short while....it nearly filled the container with foam.....what the hell..
    Feb 2005
    469
    I'm guessing that you used pure propylene glycol with water. Get some PG antifreeze if you can, it has an anti-foaming agent in it.
    Foaming for me always meant either air trapped somewhere or air being sucked into the system somewhere.
    Use pure water and aluminum safe anti freeze.
    DO NOT ADD CHLORINE BLEACH as it will corrode the water passages shut in the tube within a few weeks, trust me
    www.classicplayfields.com
  1. We supply you CO2 laser machine also laser tube
    By masterandroger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2010, 04:41 AM
  2. 70w laser tube
    By lamicron in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-10-2008, 03:19 PM
  3. Laser Tube Help
    By FlyGuy007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-06-2008, 08:50 PM
  4. Is my laser tube ok?
    By PaioX in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-23-2007, 09:34 AM
  5. bad laser tube
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-04-2007, 04:23 AM
