586,251 active members*
3,528 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Feb 2011
    Exclamation How does a computer trasmit Gcode?
    I am interested in writing my own CNC control program. How does the computer actually transmit the gcode? I assume one line of gcode is transmitted at a time and there must be some kind of response by the hardware-based interpreter giving the go-ahead to continue on.
    Can someone point me towards a communications spec?
    1. Open parallel port
    2. ??
    May 2007
    781
    That is going depend on the "hardware-based interpreter".
    You need to pick one and read the programming manual and have a chat with the manufacture of the unit.
    Any decent unit would come with souce code samples and a library of functions to make things easier.
    Feb 2011
    Quote Originally Posted by Andre' B View Post
    How does a program like Mach3 work then? Mach3 can talk to a number of different drives, and you just provide it an XML configuration file about your drive and that tells it how to talk to the drive.
    Surely there has to be general purpose guidelines for this. This stuff has been around since the 70s!
    Dec 2003
    24221
    Quote Originally Posted by JJDennon View Post
    But in different formats and methods, the original commercial systems used (uses) all in one proprietary co-processors for the HMI, CNC & PLC controllers.
    Then came the PC based Motion cards such as Delta-Tau, Galil and Acroloop and the PC just provided the HMI, the cards closed the motion loop the same way the commercial systems do.
    The method Mach uses is an HMI that also calculates the machine trajectory, this is then passed over to the motion drives via the P.P. Mach then relies on the stepper or in the case of servo's closed loop drives to complete the move.
    IOW, there is no feedback to Mach (non-closed loop).
    Al.
    Albert E.
    Feb 2011
    So what does Mach actually transmit to the drive then? It's it gcode or some modified, compiled thing?
    Al.
    Mar 2004
    1806
    Basically, Mach sends a timed data string of pulses for step and direction out the parallel port. Nothing more, nothing less. All of the computation to covert G-code to timed pulses is done in the computer.
    Art
    AKA Country Bubba (Older Than Dirt)
    35538
    All the .xml file does is contain the Mach3 configuration. All it really does is tell mach3 which pins to send the step and direction signals.
    If you want to know more about how Mach3 works, download the plugin SDK.
    Feb 2011
    Great idea, should give me a better understanding on that. There is also EMC2 as well.
    35538
    What Mach3 does (when used with the parallel port), is take control of the PC to get very precise timing. It then calculates the required step and direction signals, and places them in a buffer, sending them out in the correct time slice. There is no response with the go ahead, the signals are sent at the pre-determined time. What Mach3 does is extremely complex, and it took Art (the author) years to get it where it is now.
    Apr 2010
    486
    My question is WHY? What do you hope to achieve which can't be done with the two fine machine controllers on the market today, Mach3 and EMC2? What features do you plan to add?
    The US Government spent several million dollars developing EMC, and it was no great shakes.
    Then a handful of independent programmers took over the program and spent years and untold (and unpaid) thousands of man-hours turning it into the product it is today (EMC2). It's a robust product which will run all sorts of different machinery with as many as 9 different axes. And at least 8 programmers still spend a lot of time trying to improve different functions and keep EMC2 up-to-date. Al has already mentioned the blood, sweat, and tears which Art has poured into Mach3.
    I don't pretend to be a brain surgeon, but consider the many functions required to run just a single line of G-code. A single line might request a cutting move with 5 axis of movement. The controller has to calculate all the geometry to the moves, and keep the cutter moving at a constant rate along the material, (which will frequently involve changing the speed of each different axis drastically). A rapid move, for example, requires not only the calculations to accelerate each axis up to speed, but needs to frequently calculate the distance left for the move and then calculate the amount of deceleration required to slow the move as to not overrun the move end points.
    Tom
    Feb 2011
    My question is why not?
    I've done some work professionally developing front ends for Fanuc and Seimens controls, and it was pretty fun work. I had the opportunity to really re-think the UI and make some improvements. The response from the machine operators and programmers was pretty positive compared to the software they were using before. The Mach3 UI is pretty archaic and rough on the eyes, the same with EMC2.
    Really there is more work here than I want to take on at this point in time, but the end result would be software that would be enjoyable to use.
    Quote Originally Posted by TarHeelTom View Post
    Tom
    Apr 2010
    486
    Interesting point about EMC2 is that one of the config entries is the interface. There are currently three different interfaces in common use (that I'm aware of), axis, touchy, and Sherline.
    The hooks are there to hook a new interface into. Many of us might welcome a new interface.
    One thing I'd like to see is a USB output for a remote (read large) DRO display with EMC2. One interesting feature might be something to compare the output from glass slides with the position output from EMC2 (and perhaps Mach3). The one minor failing point of using steppers is that you have no way of knowing if the steppers are still in sync with the controller.
    So have at it. Develop for us a new interface for EMC2.
    I'm not a Mach 3 user, so can't comment on their interface, or their hooks (if any).
    Tom
    Dec 2003
    24221
    If you really need a project, look in to making a CNC HMI interface for Galil.
    The only one on the market is Camsoft, and they price it out of the market.
    If anyone comes up with a decent one cheap, I reckon they could make good money out of it.
    Al.
    Albert E.
    35538
    It's much easier to create a Mach3 screen, then create a new mach3.
    Here's two that I've done.
    The CNC Woodworker - Mach3
    Feb 2011
    Really a lot cleaner UI than some of the screensets I've seen. The major problem I see with the way Mach3 does things is the guts of the screen are bitmaps. The text is part of the bitmap, so not localizeable.
    This was the best way of doing it when Mach was originally developed, but there are better options now for developing really rich UI with tools built into Windows or by using Mono on Linux.
    With EMC2, it would be interesting to investigate the possibility of creating a front in C# end using Moonlight/Silverlight. Definitely something I'll be looking into at some point.
    Feb 2011
    100
    Other than the UI's listed, Ive seen a few others that are very nice.
    We are waiting to see your new UI. Get to work.
    Apr 2010
    There are a few reasons why people are looking for alternatives to EMC and Mach3:
    1. They don't want a PC in the workshop
    2. The parallel port is DEAD
    3. These products are overkill for many users
    We build machines and drivers, why not controllers?
    35538
    Apr 2010
    You're hanging onto the past, Gerry ... after all, there are places where you can still buy buggy whips, car starter handles and other transport archaeology, but you don't often see them in modern car showrooms
    Go to a major computer retailer and count the number of notebooks and netbooks that have parallel ports. You MIGHT find one. Count the number of desktops that have parallel ports. Heck, it is getting hard to FIND desktops in many retailers, the tide of notebooks and netbooks is washing them away. Count the number of Macs and iPads that have parallel ports. None. Android? None.
    The commercial USB interfaces have proven that it is possible to drive CNC machines without a parallel port. The Arduino guys (self included) have probably 20 competing projects running, none of which use a parallel port.
    I'm really surprised that the EMC and Mach guys are so rusted on to the past.
    35538
    Quote Originally Posted by Ron Dunn View Post
    Well, there's only one "Mach guy", so development is a bit slow. There hasn't been a new version in a few years, although one is being worked on.
    There are at least 3 USB options that work with Mach3, as well as a few other options. I've heard that parallel port support will go away, though. Possibly in the next version, probably for sure in the one after that.
Page 1 of 2 12
  1. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  2. Running a gcode output file in the computer
    By Palafox in forum Uncategorised CAM Discussion
    Last Post: 06-10-2008, 11:56 PM
  3. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  4. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
