Hi mentors,
I need some help with my current problem loading G-code into Mach3.
I drawn a part by Solidworks 2010, then used MasterCam X3 to generate G-code. I used pocket feature (from tool path) on the drawing part. It successfully verified the toolpath from MasterCam and generated G-code saved as .NC file.
I uploaded the .NC file into Mach3 to run the program on my Hobby CNC. The toolpath on Mach3 just showed an empty block. I don't know why. I previously could generate the simple program with a rectangular and drill couple holes. But it didn't work with the more complicated program.
Your help is greatly appreciated.
rainnyday
