586,089 active members*
3,820 visitors online*
Results 1 to 9 of 9
    Feb 2007
    314
    spindle alarm 409
    control:0-MD
    alarm 409. on the spindle amplifier, led indicate number 12.
    what does it mean? how to fix it?
    24221
    Ouch ...$$$.
    Unfortunately this usually due to the IGBT transistors shorted.
    The firing board should also be checked before a blanket replacement of the semi's, if this is in fact the case.
    Al.
    Albert E.
    Feb 2007
    314
    how to check if it'is the IGBT. Can i replace only the transistor or it is easier to ship the amplifier to fanuc and buy a new one?
    Feb 2007
    314
    could it be caused by anything else outside the spindle amplifier module. If I change all the module, can i be sure that it will fix my proplem. Do you have a shematic of the amplifier(A06B-6082-H211#h512) What is the firing board?
    24221
    The IGBT can usually be checked with a meter for shorts, I have replaced them only to have them blow as soon as power up, they are not cheap, so now I just send them in for a complete check including the firing board.
    There is North American Industrial in Mississauga that repair them.
    Al.
    Albert E.
    Feb 2007
    314
    changed igbt and it works again.
    24221
    Lucky you.
    Al.
    Albert E.
    Mar 2011
    O Alarm 409 no spindle serial se refere a comunicacao entre o spindle e a fonte ou o spindle e o cnc.
    obrigado
    Sep 2019
    Unhappy spindle alarm 409
    hellow, i`m operate CNC machine for last one week there is showing spindle alarm 409.
    Tell me whats its mean, and how can we overcome, as soon as possible help me with the nick of time so that i will able do work with previous speed.
    contact:03238829713
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. 750 ALARM SPINDLE-1 ALARM DETECT (AL11)
    By PICMAN in forum Fanuc
    Last Post: 03-28-2011, 12:14 AM
  3. spindle alarm 5
    By cnt in forum Community Club House
    Last Post: 12-03-2009, 05:32 AM
  4. spindle alarm
    By bhupinder in forum Fanuc
    Last Post: 01-31-2008, 08:24 PM
  5. Spindle Alarm
    By phoodieman in forum Daewoo/Doosan
    Last Post: 03-17-2007, 01:06 AM
