586,121 active members*
3,643 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mitsubishi post processor for MC ver. 7.2
Results 1 to 12 of 12
    May 2004
    50
    I Need post processor for Mastercam ver. 7.2
    We have 2 sits of Matercam ver 7.2 (yes is old but its working)
    Myself I use Cimatron so I have no glue above Mastercam,person how is using it has no idea how to modify post.
    If someone has can you email me please.
    I am looking for Mitsubishi model M-V60C with controller MELDAS 300M
    thanks
    :drowning:
    Jun 2005
    305
    Attach a copy of YOUR .pst and .txt file along with the changes you would like done.
    We will be able to help you and comment in the corrected post what we did.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    May 2004
    50
    Quote Originally Posted by ObrienDave View Post
    OrienDave
    Thanks for help.:wave:
    So far we are able to get post work,if I cross some problems I will aks you for help.
    (group)
    Feb 2011
    24
    i need help too
    hello everyone I am looking for a post to my seibu wire edm machine. I am currently using a fanuc post that I found in mastercam wire 7.2, but I have lots of problems. For example my machine doesn't allow dots(.) so in every bloc I have to erase them. And where I have I2. ( for exampe) J0. ( in post where I or J are 0 the post doesn't put them at all) I Change it to be- I2000 J000 and that worries me because I can make a mistake very easily. 2 days ago I lost a customer because I messed something up in the post.... if anybody can help I would be grateful. Here's what my post looks like
    before:
    O0000
    N100 G0 G20 G91
    N102 G92 I1. J0.
    N104 M60
    N106 S101 D1
    N108 G1 G50 Y4.5
    N110 G3 X-.5 Y-.028 J-4.5
    N112 X5. Y-4.472 I.5 J-4.472
    N114 X-4. Y4.472 I-4.5
    N116 X-.5 Y.028 I-.5 J-4.472
    N118 G1 Y-4.5
    N120 M50
    N122 M30
    after:
    W001
    N108 G1 G41 Y4500
    N110 G3 X-500 Y-028 I000 J-4500
    N112 X5000 Y-4472 I500 J-4472
    N114 X-4000 Y4472 I-4500 J000 M01
    N116 X-500 Y028 I-500 J-4472
    N117 G3 X-500 Y-028 I000 J-4500
    N118 G1 Y-4500
    N119 X500 Y028 G40
    N120 M02
    It's in millimeters. PLEASE HELP
    Jun 2005
    305
    msavcic,
    Is it trailing zero, .01mm or .001mm?
    Feb 2011
    24
    Here's the .zip file where I have my .pst and .txt file. the trailing zero is .001 , I think you should be able to see what should be changed from my previous post.
    At the beginning of the post instead of O0000 there should be W001
    Everything from the bloc N100-N106 has to be erased
    In the bloc N108 you can leave G50 because that is never the same
    ALL DOTS HAVE TO BE ERASED
    AFTER DOTS THERE HAS TO BE 3 DECIMAL PLACES(after we put 3 decimals we delete dots)
    We fill in the decimals with 0-es like .5 should be .500
    In a bloc where there is just I or J we put I000 or J000 (you could see that in my previous post)
    And finally at the end M50 goes to M02
    Everything after that is erased N** M30 and %(are erased)
    That's about it of the changes that should be made in the post...
    THANK'S IN ADVANCE
    Attached Files Attached Files
    Jun 2005
    305
    Ok, got it.
    I will see what I can do.
    Can't promise it real fast.
    Jun 2005
    305
    Ok,
    I have most of it fixed.
    PLEASE TEST BEFORE USING!!!!
    If you need other things fixed, please use the same code before and after your corrections.
    It makes it easier to find the proper places in the post to make the changes.
    If you can, please include a sample MC9 file.
    Feb 2011
    24
    Thanks for your help the dot and the decimal thing is perfect. But what are those on the right like (plin plinout 142)?? I can't put my finger on it.. all else is great. Can you help me just one more thing I don't know did you understand me with the I and J thing, but where's an I there has to be a J, or otherwise. for an example:
    X1000 Y-1000 J301- there has to be an I in front of the J, so it's like this- X1000 Y-1000 I000 J301
    or otherwise:
    X1000 Y-1000 I301 GOES TO X1000 Y-1000 I301 J000
    If you could do this for me I would be grateful forever. The work you did on the rest of the post was great there were some minor mistakes at the beginning of the post like instead of W000 it's W001 and I don't need that N100 M60 bloc but that I will change manually. so if you could see just these two things I would be very, very grateful
    THANKS FOR THE HELP
    Jun 2005
    305
    Sorry about that,
    The extra junk at the end of the line is because I forgot to turn fastmode back on.
    Here is a new one for you.
    I think I have the IJ arc problem fixed.
    The number after the W comes from YOUR program number box in the toolpath.
    I can hardcode a number there if you like but I recommend leaving it this way.
    PLEASE BE VERY CAREFUL BEFORE USING ON A PART.
    Your welcome
    Feb 2011
    24
    The post seams to be working perfectly. Thank you for your help. The only thing left is for you to tell me what do I owe you. Please put the price and I will send you the money.... DDD THANK YOU
    Jun 2005
    305
    I appreciate the thanks.
    You do not owe me anything.
    I do this because I have spent a lot of years and money learning this stuff.
    You can pay me by helping others when you can.
    Good luck.
  1. Mitsubishi Post
    By projay in forum GibbsCAM
    Last Post: 10-27-2008, 11:36 PM
