I have no clue about hydrodynamics, so I was wondering if anyone sees any reason I couldn't pump spindle coolant through the two smaller internal chambers that run the length of a 3060 t-slot gantry, using the gantry as a big heat dissipator?
I think it would be pretty simple to pump the coolant into one of the ports on the end cap, pictured below, then out through one chamber and back through the other then to the spindle and finally back to the pump. This way, plumbing would be minimized and other radiators would be eliminated.
I know it's a bit of overkill pumping the coolant through 120" (60" out and 60" back) of aluminum, but I want the ports to be on one side of the machine only.
Thoughts?
--Mark
The end plate on the left would have one line connected to the pump outlet and the other line connected to the spindle inlet. The other end cap would be on the opposite end of the gantry and simply plumbs one of the smaller inner chambers inside the gantry to the other:
