Well, I guess it's time for me to post about a problem I've been trying to solve for a week now. My Y axis isn't smooth during it's travel and it's leading to a rippled surface finish. I'm pretty sure it's related to the gib adjustment. I had no issues until my new machine worn in a little bit and I had to adjust the gib because the table was loose.
I've tried half a dozen times to adjust it and I get the same results every time. I loosen the gib screws up and then evenly tighten till I feel resistance. I check that the table moves smoothly and I also check for play by moving up/down/left/right. I adjust until there is no play and the table still feels relatively smooth. I then lock down the nuts.
The table will sound good and move well and then I'll start a job. It seems to start off well but quickly I start to hear that slight uh uh uh noise that tells me it's not moving smoothly like it should. It's much like a vibration related noise and it only happens with a load applied. If I try to adjust it loser I can feel play in the table and hear it during cutting. I've even taken it off the base a few times to clean/lube/etc and that hasn't helped.
Here is a picture that shows what I'm taking about. You can barely feel them...but you can still feel them unlike the X axis which is nice and smooth.
