586,974 active members*
3,452 visitors online*
Page 1 of 3 123
Results 1 to 20 of 58
    Jul 2007
    177
    Mobile Mill To Go
    1 week ago I started to setup a new project :
    Target spec ist to create a fully capable 3D router with maximum working area possible in respect to the following restrictions:
    Weight - below 30 KG - Airfreight compatible!
    Same cutting power as my big machine with appr. 200 KG
    Capable to cut aluminium plastics and other prototyping materials
    Fast assembly and disassembly like a killer gun
    Dimensions in disassembled state to fit in a pilot case or similar transportation and protection casing
    And so I went on ...
    Machine frame is made from fine planned aluminium
    equiped with modified professional linear tec
    motors will be stepper motors and Spindle will be a 700W to 1KW high speed AC spindle
    Attached Thumbnails Attached Thumbnails DSC07819.JPG   DSC07823.JPG   DSC07824.JPG   DSC07820.JPG
    Why reach for speed, when you could have precision instead!!!
    Apr 2010
    486
    This looks like a fun project !
    Tom
    Jul 2007
    177
    Hope it will be ! Thanks!!
    Mar 2009
    178
    sooo...how bout that business model?? lol.. jk.
    Jul 2007
    177
    Nope .. Its just a coarse idea but before talking about it I will have to prove it ... ( until that point is established I just invest in the long term activities and low material costs... the plained aluminum for the frame is about 200 the additional effort lateron is 2.5 thousand... so I keep that secret at the moment..
    the BC that was one of the first questions in the German forum without placing the first remark ...( but I should have learned .... reversible psychology works )
    Jul 2007
    177
    Now I got a bit further - Nut and bearing blocks are cut and lightened
    and today I decided to get into the fixation elements for the loose side block
    including the "O" for the inductive reference switches...
    Feb 2010
    331
    Cool machine.
    Jul 2007
    177
    Hope it will be ... Did the endplates for the x Axis today ... now its ready for the linear tech ... but the others are still missing!!!
    Apr 2007
    663
    Brilliant idea; exquisite engineering; stunning execution.
    Oct 2007
    269
    I like the lightening technique and workmanship quality on your plates. When finished, these machines will be functioning, crafted works of art. Real nice work :cheers:
    Jul 2007
    177
    Thank you guys for that comments - I really try to get this single piece done to a certain level of satisfaction for me .... I 'll do this one once and try to get it done as good as I can!!!
    Jul 2007
    177
    Here is a little bit of finishing work ( fine plain Alumium is not available in thicknesses below 10mm so I tried to give my 5mm normal plate a shiny look
    In Swizerland they would call it " Genfer Streifenschliff"
    Apr 2009
    5516
    Airfrieght? Did you have me in mund? Awesome work, keep it coming!
    Jul 2007
    177
    Target is a mobile mill ... so I try to avoid getting in conflict with transportation limits... ( I only wished to gert her below 20 KG to be able to take it in the cabin.... but perhaps I'm able to separate the controller and the spindle from the machine frame to get below this limit!
    Jul 2007
    177
    About 10 to 15 hours later ...
    Y Axis Basement is also done
    ( It's a kind of modular concept which allows me to get it more compact when disassembled)
    Jul 2007
    177
    some more progress on the adaptor plate of the y->Z Axis TTHe plate will carry the Y nut and waggons and also will be the interface to the removable Z axis!!
    Jul 2007
    177
    slowly ... slowly ... As teh job recently is taking all my time , I just managet to finish one part ... the second will probably be finalized next week....
    Jul 2007
    177
    ... It comes together!!!
    Second is a first proposal to disassembled box /stack dimensions
    Attached Thumbnails Attached Thumbnails DSC07853.JPG   DSC07854.JPG   DSC07855.JPG
    Jul 2007
    177
    ... Today I had a lazy afternoon ... just three holders/ covers for the fixed bearing side...
    Like this one...
    Jul 2007
    177
    Before I forget ... here is a first proposal - in disassembled and assembled ( still with out the side stabilizing structure) state
Page 1 of 3 123
  1. Spindle information for Various Milling Purposes
    By joprinz in forum Uncategorised MetalWorking Machines
    Last Post: 09-19-2008, 11:16 PM
  2. Spindle information for Various Milling Purposes
    By joprinz in forum DIY CNC Router Table Machines
    Last Post: 09-01-2008, 02:30 PM
  3. Mobile base for IH Mill
    By ProGunOne in forum Charter Oak Automation Support Forum
    Last Post: 01-16-2008, 11:03 PM
  4. Commercial CNC mill - BZT and Heigh Z
    By Kent_Norway in forum Commercial CNC Wood Routers
    Last Post: 10-01-2007, 02:50 PM
  5. Partime Position for Jobout Purposes
    By frickles in forum Employment Opportunity
    Last Post: 09-30-2007, 12:33 PM
