Mobile Mill To Go
1 week ago I started to setup a new project :
Target spec ist to create a fully capable 3D router with maximum working area possible in respect to the following restrictions:
Weight - below 30 KG - Airfreight compatible!
Same cutting power as my big machine with appr. 200 KG
Capable to cut aluminium plastics and other prototyping materials
Fast assembly and disassembly like a killer gun
Dimensions in disassembled state to fit in a pilot case or similar transportation and protection casing
And so I went on ...
Machine frame is made from fine planned aluminium
equiped with modified professional linear tec
motors will be stepper motors and Spindle will be a 700W to 1KW high speed AC spindle
Why reach for speed, when you could have precision instead!!!
