It depends on what resolution you require and if scaling is possible, it should be in AB.
I have never integrated an AB or even done much work on them, they are scarce around here.
But I am sure they will also multiply the quadrature pulse x4 as most systems do to get maximum resolution from the encoder.
Also if the encoder is on the motor and there is gearing between it and the table this will also increase resolution.
Al.
Albert E.
