586,060 active members*
4,487 visitors online*
Page 6 of 18 4567816
Results 101 to 120 of 350
  1. #101
    Jun 2003
    205
    Re: All Post Processors
    Isn't it time to put an end to the post processor madness?
    Wouldn't you like to use a generic post like FANUC ... then run that code through something that will auto convert it to your machine ... Dynapath, Siemens, Okuma ... whatever?
    How about the ability to take a proven G code program running on one machine ... and auto-convert it to run on another machine? ... without re-posting it and losing all the edits that had been made !!
    That time has come ... KipwareXC and CNC XChange from Kentech Inc. can make that happen.
    Here's a couple of links for additional information :
    Article : http://kentechinc.com/kipware_blog/w...-and-obsolete/
    Product Info : Kipware CNC G code conversion software from Kentech Inc.
  2. #102
    Nov 2008
    412
    Quote Originally Posted by BlueChip View Post
    Article : Why CAD/CAM Post Processors Are Old School And Obsolete | The Kipware Blog
    YEAH. As long as is free..
    Forget about global warming...Visualize using your turn signal!
  3. #103
    May 2006
    803
    Bluechip and all the others suffering with the mysterious postprocessors,
    Back in the old school days (1970's ) we had "Binary Cutter Location"
    There were 100+ machines all running the same data format, 7" floppy disc.
    posting was done internally at the machine control. Vega controls.
    Eliminated all problems, did major machined structures 3-5 axis three spindles..
    Seems like those machine control E.E.'s keep changing things when it was all figured out and in use.
  4. #104
    Jul 2017
    just a couple i have
  5. #105
    Aug 2017
    Hi Claudiu220405,
    Thank you for this files. If you have worknc post files then please share with here is my mail id - [email protected]
  6. #106
    Hey guys
    I have problem with Heidenhein MillPlus IT PostProcessor in SolidCAM.
    When I generate G-code, CAM always create txt file instead pm file.
    Unfortunately I alredy change to generate into PM extension in PRP file. What do I do know?
    If anyone knows pleace help.
    Thank in advance
  7. #107
    Sep 2017
    HELLO, IM LOOKING FOR A POST PROCESSOR FOR A HAAS VF5 FOR ESPRIT ANY ASSISTANCE WOULD BE GREAT THANK YOU ......KEVIN
  8. #108
    Aug 2014
    6
    Quote Originally Posted by claudiu220405 View Post
    Thanks for your pp. I also paid a lot for my posts, but F*** with payng the posts.
    Let everybody use them.
    I also have post for DMG DMC 635V with sinumerik 840d. If somebody want them I can upload.
    Hello Claudiu,
    Can you please upload the post for DMG 635V with sinumerik 840D?
    Thank you,
  9. #109
    Sep 2017
    Hi all,
    can someone help me? I´m looking for a postprocessor Siemens 840 for Starrag SX51.
  10. #110
    Sep 2017
    Hello everyone,
    I am new to CNC machines, & I am a part time hobbyist, iam constructing 5 Axis CNC milling machine TABLE-TABLE type. I have masterCAM-2017 cracked version, on that I find Haas VMC post processor similar to my machine too , Has been generated G-code by using Hass post processor for my component, but the thing I need to know how to change machine operating dimensions of XYZAB axis's , it is giving me 76mm to move in z axis for home position since my machine can move only 48mm in Z axis. IS there any parameters (working dimension) need to modify in Post processor or in machine definitions ? if machine definitions need to modify then how to modify those parameters?
  11. #111
    Sep 2017
    Hai,
    Need Mach3 5 axis milling machine post processor for masterCAM-2017 can ant one help me??
  12. #112
    Aug 2008
    406
    I thought a standard Fanuc post would work...
  13. #113
    Dec 2006
    I need post processor for xilog plus SCM RECORD 1100 for alphacam program. Do you have it?
  14. #114
    Oct 2017
    HELLO, IM LOOKING FOR A POST PROCESSOR FOR A FEGOR 8055 HMC ANY ASSISTANCE WOULD BE GREAT THANK YOU ......SUKHVINDER SINGH
  15. #115
    Apr 2015
    327
    let me know.
    [email protected]
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  16. #116
    Mar 2014
    5
    Hi to all.
    I am searching for a Post for fanuc18i-T lathe with sub spindle and live tooling.
    Is there anyone that can help me on this?
    Thanks in advance
  17. #117
    Apr 2015
    327
    Quote Originally Posted by dimraft View Post
    Hi to all.
    Thanks in advance
    Which cam?
  18. #118
    Mar 2014
    5
    SOLIDCAM OR INVENTOR
  19. #119
    Dec 2008
    I need Mitsubishi M70 Post Processer for Siemens NX11
  20. #120
    Oct 2017
    please upload it
  1. Post Processors
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 02-19-2024, 08:40 AM
  2. Post processors....
    By jame5m28 in forum Uncategorised CAM Discussion
    Last Post: 02-19-2024, 01:07 AM
  3. post processors
    By ltemp in forum Community Club House
    Last Post: 01-19-2014, 04:28 PM
  4. What are post processors?
    By raworkshop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2009, 12:10 PM
  5. What are 'post-processors'?
    By Countryman in forum Uncategorised CAM Discussion
    Last Post: 07-15-2009, 12:55 PM
