586,682 active members*
2,855 visitors online*
Results 1 to 7 of 7
    Mar 2011
    Bridgeport 760 warm up cycle
    Does anyone know the program to overite the warm up cycle my boss does not want to use it at start up thanks
    1121
    there is no information here
    "my car is funny when I start it, can you tell me what is wrong"
    Oct 2009
    51
    VERY BAD IDEA!!!!!
    Not warming up the spindles on the new Bridgeports is a VERY VERY VERY VERY VERY VERY BAD IDEA!!!!!!! I only say this because I've changed many of these because people didnt do it. There is a reason why Hardinge put this cycle in there automatically! These spindles do not have bearings that are "greased for life" These machine contain a spindle that greases itself based upon on and off time of it. Hence the longer the machine sits off, the longer the warm up cycle is. This cycle is disigned to inject the correct amount of grease into the bearings and distrubite the grease correctly within the bearing.
    With that being said, your machine, you decision how to use it.
    Need the service key on, hold feed hold and spindle stop down untill message goes away.
    P.S. These machines have $13,000.00 spindles!
    Mar 2011
    Thanks For the info we are putting in a rebuilt greaseless bearing spindle are grease canisters went bad and gave no warning or alarm so we are omiting them. have another question we broke a fitting on the part they call a joint it sits ontop of the spindle one fitting is on top and the other is on the middle on the rounded side we can find what thread size it is the fitting is a reducer fitting we tried npt and bspt and neather will fit do you know the thread size of that fitting? I tried are parts guy and he ran into the same problem I did its not listed in the parts book. Thanks for the help David
    Mar 2011
    Quote Originally Posted by Nawrocki4Life View Post
    Oct 2009
    51
    Rotory union
    Well that machine is built in Tiawan so I would assume some goofy metric size. That fitting is pressure relief for that union. In case something gets clogged in the spindle while using through spindle coolant. So that barely gets used under normal conditions. I would just get a fitting that would start and force it some into it. Or since you have it off, drill and retap it. other then that maybe you gotta order the repair parts from your Hardinge dealer.
    1121
    force it in, that's a good idea
    perhaps it is a flare size, probably a straight metric thread
    something like a JIC swivel
    probably getting the right part is the answer
  1. BRIDGEPORT MILL PROGRAMMING CANNED CYCLE
    By ACERUPE in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2010, 06:41 PM
  2. Warm Up Cycle Problem ???
    By xray34 in forum HURCO
    Last Post: 04-07-2010, 08:36 PM
  3. warm up cycle
    By gorby in forum Haas Mills
    Last Post: 02-02-2010, 06:09 AM
  4. Bridgeport stopping in cycle
    By pinkminky in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2008, 01:07 PM
  5. vmx 24 warm up cycle time
    By isar in forum HURCO
    Last Post: 07-31-2008, 06:10 AM
