I've been futsing around with micro controllers and have written and developed a working DTHC control based on the Atmega328 AVR that runs via Modbus RTU over USB and is MACH3 friendly.
It allows you to keep parallel inputs for other stuff and as a bonus it gives you 8+ I/O pins to fill up as you desire (automatic lunch e-stop at noon?)
The code and control side work great but I'm having random spike, noise, and RF issues that I would like to get gone and need some help/guidance with filtering / rectifying so the A-D converter is happy and stable.
My current setup is of the bridge rectifier to voltage divider to low-pass filter variety and although it works pretty dam well, my ref voltage swings more than I think it should.
I'm looking for help in the processing of the raw tip voltage.
As an aside. Here's a cool Diesel to Veg Oil heated aluminum tank I just cut and welded on my ebayified table.
