Hi all,
I'm making some parts from G10 & CF sheet. I am using tab and slot interfaces at 90 deg corners. Trying to find a way to cut the corners so the short dimension continues to clean out the corner. Imagine a 1/8" slot cut with a 1/16" tool, want it to look like an "I" so the tabs will slide in. I have been using biscet corners, but I loose too much of the end of the slot which is where the load is. Hoping I don't have to draw all the corners! Using V23.
TIA,
Doug
