586,626 active members*
2,321 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to cut large diameter thread with milling machine.
Results 1 to 8 of 8
    Sep 2010
    Dear masters..
    How can I cut a large diameter thread (female and male) on a mini milling machine?
    Tools?
    Steps?
    Methods?
    Pictures?
    Thanks a lot
    May 2008
    1185
    Single point thread milling.
    Mach 3 does it and you can make your own cutter or buy a insert and make a holder.
    Youtube has a few videos.
    Sep 2010
    Quote Originally Posted by arizonavideo View Post
    Thanks.
    I am having a manual milling machine similar to harbour frieght. No CNC. Is it possible to do it manually?
    Sep 2010
    Thank Arizonavideo,
    My machine is not CNC. Its a manual machine similar to harbour frieght.
    May 2008
    1185
    What is larger?
    For a mill you can buy a tap or find a lathe if the part can be mounted on a lathe.
    Their my be a way to make a jig to allow you cut a known pitch on a round stock but I have not seen one.
    Sep 2010
    Large like 60mm diameter. Any thread type will do because I will do the same for the male and female side. I dont have a lathe machine and no tap that size.
    Form tools or jig? I have not seen one too.
    May 2007
    781
    Do some research on Joseph Brown of Brown & Sharpe and his universal milling machine.
    Area Attractions
    VintageMachinery.org - Brown & Sharpe Mfg. Co. - 1919 Image- Brown & Sharpe Heavy Universal Milling Machine
    Basically you need some kind of gearing between a rotary table/indexer and one of the slides, probably the Z axis.
    In Brown's time that gearing had to be mechanical and in some cases it could get very complicated (variable length drive shafts, universal joints etc.) but today it would be a lot simpler to put a servo/stepper motor on the rotary table and the Z axis and do the gearing in a computer.
    Sep 2010
    Thanks all,
    I guess its either electonic control (CNC) or motorise the z axis and rotary table. Otherwise it is too complicated.
  1. large diameter workpieces on sl-30
    By pmurdock in forum Haas Lathes
    Last Post: 07-28-2009, 06:15 AM
  2. Drilling / Milling Stone - Large Diameter Ball End Mill
    By oscarbam in forum Material Machining Solutions
    Last Post: 08-27-2008, 11:29 PM
  3. Thread milling in a machine center
    By jorgehrr in forum G-Code Programing
    Last Post: 08-06-2007, 01:58 AM
  4. large diameter end mills??
    By jlembas in forum MetalWork Discussion
    Last Post: 06-08-2006, 03:12 AM
  5. Large Diameter Drilling
    By PolyPill in forum Material Machining Solutions
    Last Post: 02-01-2006, 02:40 PM
