586,094 active members*
3,993 visitors online*
    Jul 2007
    TM 2 safety switch
    Read somewhere about over-riding the safety switch on the TM 2. Of course, this is bad thing to do, but how is it done? BTW, our mill was just repaired by a service tech and this was never a problem before then.
    Nov 2007
    1702
    You have the pushbutton switch on the cord, right? I was told by somebody that they just use one of those big, black spring paper-clips over the top. They open it up, put it over the end holding the button down and let it grip the handle. If a safety person comes over, they just pop the clip off.
    Your tech was probably instructed to do it by the HFO management which probably came down from Haas. In our litigious world, I don't know why it's taken THIS long to get where we are.
    Sombody may also PM you the fix. I can't remember which but, you have to switch a parameter or two as well as use the Door Hold Override setting to get it back the way it was.
    Edit: am I going to hell for posting that?
    Greg
    Jul 2005
    12177
    Nov 2007
    1702
    That's it and you weren't even the guy I was thinking of. That's funny.
    Is there a picture of that in the user's manual or something?
    Greg
  1. How to turn off the open door safety switch
    By dingo0722 in forum Haas Mills
    Last Post: 01-21-2011, 12:40 AM
  2. safety conscience, or safety paranoia?
    By Marino MFG in forum Safety Zone
    Last Post: 04-03-2009, 09:34 PM
  3. TM-1...Need to disable "safety switch"
    By jwknow in forum Haas Mills
    Last Post: 01-16-2008, 05:52 AM
  4. EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE
    By Epik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-27-2005, 11:20 PM
