586,102 active members*
3,266 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Trouble With Modifying Mpost
    Apr 2009
    46
    I need to Change the drill cycle to suit my machine But it is not working out. Here Is what I need the drill cycle to look like
    P01 -.125 P02 -.500 P03 -.050 P04 1 P05 30
    P01 = r plane has to be a negative
    P02 = total hole depth also negative (zdepth?)
    p03 = peck amaount also negative ( vbite?)
    p04 = dwell time in seconds
    p05 = feedrate no decimal 30 = 3.0 ipm
    This is a peck cycle G83 on my machine. For a regular drill with no peck
    the P03 need to be the same as P02.
    any help would be appreciated
    Marcus
    Attached Files Attached Files
    Mar 2008
    7
    What operation are you selecting inside surfcam?? The reason i ask is that your post has two G83 cycles in it and they are both different. Also if you could include what it is posting out and what you want the code to look like its easier to troubleshoot.
    Apr 2009
    46
    I am using a drill cycle. The first is a spot drill then a drill cycle. .300 for depth of drill cycle. My Machine uses G83 for spot drill, drill, and peck cycle.
    I Atached what i get. Here is what it is suposed to look like
    Drill Cycle
    N40 t1 g17 s2000 (tool call)
    n50 g83 p01 -.100 p02 -.300 p03 -.300 p04 0 p05 100 (cycle)
    n60 x.500 y.500 m03 (position in x and y)
    n70 z.100 m99 (position to clearance call cycle)
    n80 x-.500 m99 (move to second hole call cycle)
    thanks
    Marcus
    Mar 2008
    7
    I have your post modified. Send me a email to [email protected] and i will send it to you.:cheers:
    Apr 2009
    46
    Thanks Joe!!!! You gave me a huge step in the right Direction. I just finished the fine tuning. I couldn't see how t do it at first. After Looking at the same thing for hours you sometimes get tunnel vision.
    Cheers
    Marcus:cheers::cheers:
  1. Mpost for matsuura 3000g
    By steelhead1 in forum Surfcam
    Last Post: 10-08-2007, 06:14 PM
  2. Replies: 7
    Last Post: 01-31-2007, 04:26 PM
  3. Mpost/Spost Tips and Tricks
    By tnik in forum Surfcam
    Last Post: 12-20-2006, 07:32 PM
  4. Modifying Servos
    By aus-newb in forum Centroid CNC Control Products
    Last Post: 12-20-2005, 01:20 PM
  5. modifying a loft
    By PTcutter in forum Solidworks
    Last Post: 06-18-2005, 01:22 AM
